Question about LG LMVM1935 Convection/Microwave Oven
Touch pad doesn't work LMVM1945SB Microwave
Touch pad doesn't work. How do you get it off the door?
    Problem Solver:
  • 4 Answers
That would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
Posted on Sep 21, 2009
  • wlparadise Sep 21, 2009
    that would be for a technician only........ electronic parts of that type are not generally self repair nor readily available
My start button of microwave suddenly stopped working only its stop button works.What can I do?
You could have a defective door switch. Or, a bad membrane switch on the touch pad. Or, the ribbon cable (if so equipped) between the touch pad and circuit board might not be making connections on all of its wires.
Sep 14, 2016 | Microwave Ovens
Start enter button not working
If you know how to repair microwaves, see these youtube tutorials:
Fixed microwave number pad
Quick repair GE microwave touch control key panel doesn
Samsung Microwave SE 5E Error Fix
Lg Microwave keypad repair
No light? You can look for more videos or take it to a repair shop
Jul 13, 2015 | Microwave Ovens
Our lg stainless steel overthe range microwave oven will not start. When pressing start only says power 100
The touch pad could be the problem. Touch pads are notorious for going bade. the door interlock switches could also be a problem. Check to see if all the pads work if they do it could be just the start pad that is bad.
Mar 14, 2015 | LG Over-the-Range Microwave
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
My microwave Oven, send a F1 messagge and doesn´t work. What can I do?
F 11 code. it is a touch pad error.
If you just cleaned the control panel it may have water in the panel causing a key to stick.
If after a day or 2 it hasn't dried out - then you will need to replace the touch pad.
Visit www.searspartsdirect.com and enter in your full model number for a parts breakdown and schematics.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$%^
Dec 17, 2009 | GE JE1390 Microwave Oven
I have the part I need, but I need to disassemble the door to install it. I don't see a way to do that...Model LMVM1945SB
Remove the outer cover from the microwave oven to gain access to the door hinges. With the door off, and lying face down on the table, carefully pop-or-pry the plastic door seal off the inside. Presto, access.
Nov 12, 2009 | LG LMVM1945 Microwave Oven
Button panel does not work or it starts making 'pick-pick' noise
The touch pad seems faulty, there may be moisture behing the first touch pad film, suggest replacing touch pad as it cannot be fixed, Phil
May 18, 2009 | Sanyo EM-S9515W Microwave Oven
LG microwave oven
It's usually a bad door switch or a broken door switch mount. Once in a while it's due to a board problem. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Jun 13, 2007 | LG LMVM1945 Microwave Oven
LG LMVM1935 Convection/Microwave Oven Logo
519 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
