Question about Singer CE-100 Futura Computerized Sewing Machine
Top thread will not pick up bobbin thread makes a big loopy mess
Top thread is stitching fine but will not pick up bobbin thread top thread jusrt leaves a big loopy mess and bobbin thread can be easily pulled out as it isn't stitched at all
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Posted on Oct 21, 2009
    New Friend:
Needle keeps hitting metal plate, and breaking
Posted on Jun 30, 2013
I dont have the same machine but on mine this is a tension problem and I experiment with different tension until I get the right one for the material and thread
Posted on Sep 09, 2012
  • 48 Answers
Make sure you follow the diagram on how to put the bobbin. It sounds that is incorrectly installed. If so, the upper thread will not pick the bobbin thread correctly.
Posted on Nov 11, 2011
  • 46 Answers
Here is the Futura web site Q&A
http://www.futura-support.com/faq/machine.htm#1
Posted on Oct 10, 2009
The lower thread on the machine is jumpy, creates a loose (loopy) stitch every 1.5 cms or so. The upper thread is taut, but makes no difference if I put tension dial on lowest setting.
Hm, if the bobbin thread stitch is inconsistent, I would guess it is a problem with the bobbin tension. You might try picking up a new bobbin case for our machine. Bobbin cases do wear out or get damaged or there may even be a burr somewhere that is catching the bobbin thread.
Something else to try, before buying a new bobbin case, is:
Avoid old or bargain bin threads!
Install a brand new needle (compatible with the fabric & thread).
Remove the top thread from the machine.
Try a different brand of thread.
ALWAYS RAISE the presser foot and rethread from the beginning.
Set the upper tension to the midway point and test your machine.
Adjust the upper tension until the bobbin and top threads meet in the middle of the fabric.
Jan 19, 2018 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
How to fix bobbin thread on computered memorycraft 9000 sewing machine ?
1)Check that your bobbin does not have a nick in it where the thread can catch and won't feed smoothly.2) make sure the upper and bobbin threads are the same.3) pull out the bobbin case and chect to see if there is a clump of lint.4) make sure the feed dogs are moving the fabric through smoothly,some fabrics can get caught on the dogs and make the bottom thread get loopy.5) check your needle,if it's bent or has a bad tip,it can mess up the stitch.
Aug 15, 2014 | Janome Memory Craft 9000 Computerized...
My machine is a Singer Inspiration 4210. My stitch on top looks fine at first glance but it is birdnesting underneath. What should I do to correct this?
Check your top tension. It sounds like it may be too loose or the bobbin tension may be way too tight. Most likely it is the top tension that is incorrect though. The TOP tension effects the bottom side of the stitch and the bottom tension effects the top. If the top tension isn't tight enough it won't draw the thread up through the top side taunt enough and the excess underneath makes a big loopy mess.
Jul 29, 2011 | Singer Inspiration 4210 Mechanical Sewing...
When sewing, the top stitch and thread is fine. when you look under it is a huge mess of upper thread. I have cleaned shuttle, fixed the bobbin, replaced bobbin and upper thread. A number of times.
Recheck the tension on the top thread. Test it before you put it through the needle to see if there's any tension. It should pull but with some resistance. Also check the needle and make sure it is the right type for the fabric and not bent etc.
Looping on the underside of the stitch is from the upper thread, usually tension problem. But do check the bobbin tension and make sure it isn't too tight, though that's not usually the problem you're describing. The two tensions need to work together in order to get a nice, flat (not puckered or loopy) stitch.
One last thing you might check too, though again this wouldn't typically be the problem - is the dogfeed moving the material along under the presser foot correctly?
Most of the time the problem you're describing is due to not enough tension on the upper thread.
May 31, 2011 | Brother Sewing Machines
I have a brother vx-1125 and the top stich is fine but the bottom one is a mess, whats the best setting to have it on for a normal straight stitch?thanks
If the bottom stitching is a mess it usually means that the TOP thread is not threaded correctly. What happens most of the time is that the thread is not snug in the tension discs. First re-thread your machine with the presser foot UP and when you get to the tension discs (sticking up at the back of the machine) hold your thread like you're flossing and go back and forth in the disc to make sure you have tension on it. You should hear a little click when it's in there. (Test it...floss it on and pull it off so you can hear the click.) If the thread isn't between these discs your bobbin thread will be loopy. Finish threading the machine and you should have no problem now. Also, make sure your upper tension is set at 4 and your stitch LENGTH (on the right front) should be 2.5 or 3 for a normal stitch. Hope this helps. Let me know! Thanks for using FixYa
Sep 10, 2010 | Brother XL-2600
I have a Bernina 130, the thread from the bobbin is coming out with huge loops, the top thread looks great, but turn over the fabric and you have a mess. Any advice is welcome.
Usually if your bobbin thread is loopy it's because the TOP thread is not threaded right. Try threading it again with the presser foot UP and make sure to get the thread between the upper tension discs. It's just the opposite of what you would think.....if the bobbin thread is loopy, the top thread is threaded wrong, if the top thread is loopy, the bobbin is threaded wrong. Good luck!
Aug 20, 2010 | Bernina Activa 130
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Jan 23, 2009 | Husqvarna Viking 1
Singer CE-100 Futura Computerized Sewing Machine Logo
564 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
