Question about Home
Need to remove newly install wall to get to plumbing, but clips are holding tight. How fo you remove wall without damaging anything.
  • 49 Answers
In most cases you can't , just try to cut a clean neet hole so it'll be easy to patch
Posted on Sep 20, 2009
Foed 302 in 1980 /up l0w vacuum low comp. on no:4 newly rebuilt engine i am tolb i got a sticky valve
possible or the cam follower or hydraulic tappet is holding the valve open/ incorrect valve clearance setting initially
stick valves are normally from bent valve stems or damaged valve stems and guides
May 30, 2017 | Cars & Trucks
How do i replace and install a new 2/25f sh. capacitor for my carrier model wcarf010ee
most likely it is in the back of the unit which will require you to remove it from the wall or window and disassemble the cover and remove the top. if it is in the control box then you may be able to do it without taking it out of the wall. always remember to unplug it first!!! all window and wall type units are very tightly packed and not very repair man friendly. take the cover of and remove the box that hold the controls.
May 20, 2011 | Heating & Cooling
There is loose wall mount tub filler. How can I tight it?
Most tub spout are pretty covers for the generic ugly pipes that deliver the water from the wall water plumbing into the tub area. Speaking for this water pipe it's either going to be copper or galvanized iron pipe. The pipe that you see sticking out of the wall is rather short. It ends just inside the wall usually at a 90 degree elbow which in turn is connected to a pipe and other things inside the wall cavity. If this short pipe stub is loose so you can move it in and out of the wall hole some, the reason is that the plumbing pipes inside the wall are not tied down to the wall studs properly.
If the backside of the wall can be opened by cutting out a section of sheetrock in the same location as where the spout pipe is located, you can expose the inside wall plumbing and tie in the wall pipes securely to the wall framing. Afterwards, you need to seal up the sheetrock hole you created.
In some cases this is not possible. When that is the case, your fix is spotty at best. You can use a caulking that becomes rock hard when cured around the pipe nipple as it comes through the wall hole. Hopefully the hard caulking will provide enough tightness tying the pipe to the wall material to help stop the movement. Install the caulking so it is underneath the pretty tub spout when you reinstall it over the generic pipe. Make sure you do not have this caulking involved with the pretty spout so if you need to remove it again, it won't be locked in by the hardening caulk.
Nimsgame
Feb 15, 2011 | Cifial Wall Mount Tub Filler Spout CIFIAL...
Jimmy 1995 JimmyLift gate will not open. I can hear the mechanism trying to work. I looked up the instruction in a repair manual. It tell me to remove the rug on the tailgate to expose an access hole...
The rug has a cardboard backing with screws and plastic clips holding it on. First remove all the screws you can find in the trim. You will need a tool like a pickle fork to remove the plastic clips without damaging the card board backing (door card removal tool). The trick here is to pull the clips out of the metal and not the cardboard so not to damage it. Start at the top by the window and it is easier to see the clips with the top loose. I have used my wifes two pronged weed puller with no problems. When you get it all apart you will see that plastic clips hold the rods to the latch on each side as well as to the release mechanism. If the clips are bad replace them. It is important not to slam the hatch or they will pop off again.
Nov 20, 2010 | 1995 GMC Jimmy
I want to uninstall a GE JVM141H microwave oven.
GE isn't listing an installation manual for that old of a model. Checkout the closest one I could find that will give you a good idea of how it may be attached.
click below
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675895.PDF
Hope this Helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Nov 30, 2009 | Office Equipment & Supplies
Replace power point plug
Remove the outer trim panel.
Oct 25, 2009 | 2005 Ford F-150
Water drains slowly from newly-installed kitchen sink and gurgles as the last drops go down the drain
sounds like you have a partial blockage in wall pipe.take of p trap and snake pipe in wall as far as you can.
May 09, 2009 | Home
Hi - The jet for the window washer fluid on the passanger side was damaged. I bought a replacement part (2L5Z017603-AA) Kit-Jet. The driver side tubing is exposed within the engine compartment, the...
no you will have to remove the wiper cowl , remove the wiper arms and any exposed clips holding the cowl down , sometime ford used Blind clips so it may feel attached after you remove any exposed screws . BE careful around the windshield !!!
Dec 18, 2008 | 2006 Ford Ranger
Lg monitor l194wt
It's not glued!!!! It's clipped together...and DON'T take out the screws first...
First, turn the monitor upside down and look at its thin edge. See where the grey bezel meets the black case? That's your clip point, all the way around the monitor. The reason you want to start here? This monitor is VERY tight, and there's a good chance you will mar the plastic, so it might as well be in the least visible place.
Next, fit a plastic trim removal tool (you have one of those, right? Right!? :) ) in between the black and grey plastic, halfway along the length of the monitor. If you have difficulty getting it in, run it back and forth until you find a loose point, but you'll eventually have to come back to the tight spot.
Here, there's a little bit of finesse required...you have to pry the grey part (which I will start calling the "bezel") gently upward, not away from the black plastic (which I will call the "case"), perpendicular to it. This will pull a clip up out of its slot. When you feel the clip release, now you can move it slightly away from the case, but don't remove the trim tool. Keep unclipping the rest of that side.
Once you've gotten the hang of it, do the next side. This bezel is particularly tight, so don't start at the edge...you will definitely damage it. Once you've gotten two sides loose, the whole job becomes easier, but still stay patient and careful, because there's a lot of potential for damage.
Now that you've gotten the entire bezel off (and the hard part is over with), hold the LCD in place as you turn the assembly face down onto a soft cloth, like a blanket or comforter. Now you can remove the four screws from the back.
Lift the case off and remove the two screws holding the switch assembly. This will lift off easily.
Lastly, partially remove the silver tape holding the electronics case on the back, carefully remove the connectors (remembering their positions, of course), and you're ready to play electronic doctor. I'm posting this with my newly repaired L194WT. :)
Jun 14, 2008 | Gateway FPD2275W LCD Monitor
How to remove tailgate cover
most car all makes these days use push clips on the hidden panel side or visible screws or smaal cicular covers hidding the screw heads or a combination of clip and screw.pull the panel towards you inspect it has a lip at the window glass then push to the sky,
Jun 02, 2008 | 2007 Honda CR-V
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
