I need my speakers to go thru the spearker output not digital output divice there is no plae i see to change to default to speakers
  • 8 more comments
  • tonya6321 Sep 20, 2009
    its on my hp pavilion a6010n pc i have the speakers in the green hole in the back of the pc just regular plain speakers
    my problem is pc is set up for digital output i have regular and there is no icon to switch them to speakers not digial output or what ever and cant see to find the software to get what i need my old speakers had sub wolfer and stuff but these do not and the out ones are not any good any more i replaced the graphics card not to long ago and not sure if that is when i lost sound or before then.... when i plug the speakers in i can hear them going in and i can hear a beef from time to time but no sound on games or when i try to play music or dvds or things like that
    no in the advanced tab that is not the one it has and its not higlighted so i cant change it to become the one you asked about... some how i have lost the software or what ever and not sure how to get it back thanks
    There has to be some way to get the option to use digital output and speakers.... really dont want to buy another set of speakers to make the sound work... not sure if its disabled in pc some where like i said i have looked every where that know of to look but that does not mean im not missing something...
    ok so i went there did the download and still a no go... its still stuck on dvd quality in the advanced setting had already done the drivers a few times but wanted to try and see one more time... and no nothing is on mute which is what a ton of people ask me next
    so i tryed that lol there are no disabled devices... they only show the one i told you about... how would i know if the sound card was bad?
    What i need is the realtek high definition audio software the one that lets you sue the green jack in the back of your pc not the one that uses the square funny looking jack that is what i am missing.... just not sure how to get it or find it or what ever am i making any kind of sence?
    Its a desk top not lap top... and its 32-bit im thinking. and i have used the speakers on a different pc and they were fine... not sure where the sound card is in the tower to take out and try on a different on... would really like to find a way to get the drivers that give me a choice to change from one out put to another before i go buy another sound card and try it
    soundcard is in the mother board so cant take it out and try on different pc.. still thinking that it has something to do with the different slots the speakers can be plugged into tho just dont know how to get what i need
  • tonya6321 Sep 21, 2009
    its in the mother board so i cant do that and no i think it is something with the different slots to put speakers in cause the one its trying to use is working... its just not the one i want to use i dnt have that kind of speaker... it is however making a beep noise now that it was not maken before when i click on something that is running or what ever
    Brigadier General:
  • 8,619 Answers
Hi
Please describe the setup of the speakers. Also tell me if they are connected with the computer or DVD Player or a Home-theater system. So, that i can provide you with correct setup instructions. Please check this diagram, this may help--
Please tell me the model number of the Unit so that i can provide you with model specific information.
Thanks for using FixYa.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Posted on Sep 20, 2009
  • 4 more comments
  • Rylee Smith
    Rylee Smith Sep 20, 2009
    Hi
    Try using another set of speakers/headset to check if its not a fault in the jack/speaker.
    If you are using Windows Vista then go to
    Please go to control panel-> Sounds-> open it and then click on configure to test the speakers, if test is not successful(no sound) then go to properties from sound dialog box opened and check for Properties-> device is enabled & from advanced tab check if the 24000bps is selected.
    If you are using Windows XP then
    1. Open the Control panel.
    2. Open the "Sounds
      and Audio Devices" icon.
    3. Verify the "Place
      volume icon in the taskbar" checkbox is
      checked. If this option is not available or is grayed out, skip to the next section of this document.
    4. If you were able to
      check this box, click ok and close out of this window and the Control
      Panel.
    5. Double-click the sound
      icon in the Systray and verify that all the sound volumes are mid-way or
      higher.
    Thanks
    Rylee
  • Rylee Smith
    Yes, I think you have uninstall the drivers for your sound card. You can download and instal the drivers for your HP A6010N from this link---
    HP A6010N Sound/Audio Drivers
    Thanks
    Rylee
  • Rylee Smith
    Please open control panel-> sound-> right click on the playback window and select the option show disabled devices-> from there enable the other device and disable the one which you are currently using.
    Now check for the Studio option. This will surely resolve your issue.
    Thanks
    Rylee
  • Rylee Smith
    To check if sound card is bad connect any other speaker or headphone. If you don't have a spare one then the only way to confirm is by removing that sound card and testing it in another laptop. I hope you are also not able to hear any sounds from the built-in speakers as well. If sound is there from the built-in speakers and not external speakers then either speakers/speaker jack is bad.
    You can install the realtek drivers from the link i gave you earlier or from your motherboard drivers & utilities CD. First try uninstalling the previous version of realtek drivers from Control Panel-> Programs & Features-> Realtek Audio drivers-> Uninstall. Restart the laptop and then reinstall it again. After the re-installation restart the laptop again.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Sep 21, 2009
    Yes, please take out the sound card and try it with another PC. I don't think that it has something to do with the different slots the speakers can be plugged because you have already tried and checked all that.
    Thanks
    Rylee
  • Rylee Smith
    The beep indicates the issue is with the sound card as it might be loose and you need to check it, or get it checked and I think the issue will be resolved.
    Thanks
    Rylee
I had some kicker 6x9 cs693 installed in my 2002 camry rear deck and when they returned the car the spearkers are not producing much sound or bass. I am using factory stereo and also the factory 6x9 on...
first check to see that the fader is not programmed to the front speakers fading it rear might solve your problem, second if your stereo has a 4 ohm load requirement at the output and your new speakers are 8 ohms this will cut the power output in half, your best bet is to get an amp if these do not solve the problem.
Feb 27, 2015 | Kicker Car Audio & Video
Sony DAV-DZ660 Theatre system. How can I change the output volume and tone for each speaker please?
there should be a speaker set up button on your remote, it will play "white noise" through each speaker in your system, one spearker at a time, as each speaker plays you can adjust its volume, the idea being to balance the system to sound good from your sitting position. try to get each speaker to be appriximately the same volume level. If you have the manual for this system, this setup should be listed in the index or somewhere.
Mar 19, 2011 | Sony DAV-DZ660 Theater System
Hi, I'm using steinberg cubase3. but after
I don't believe your Bose speakers are digital, you need to change your audio settings on the output to analog speakers.
Mar 17, 2011 | Steinberg Cubase 4 ( Windows / Macintosh )...
How do u hook up the infinity entra sub it has speaker level(input and output) that look like these red and black spots r for spearker wires and then line level input so I connect my music to the rca plugs...
Maybe if you described the setup with exact model numbers for everything involved we might be able to answer with specifics.
You could poke around her for the Entra Manual for YOUR model.
http://manuals.harman.com/INF/Hom/Owner's%20Manual/
What they do NOT explicitly tell you is that the amp in the sub is not for your other speakers running off it's Speaker Level outputs. They're just there as a pass-through if you use Speaker Level from your own amp.
Line Level (RCA) IN to the sub will NOT pass anything out those Speaker level outputs.
Jan 13, 2011 | Infinity Entra Sub Subwoofer
I do not get sound from my speaker, the control panel shows it to be sending a digital signal. How do I change it to analog so the speakers will work.
Try changing the default sound device from high definition audio output to speakers. You can find it under sound in control panel.
Oct 12, 2010 | Acer Audio Players & Recorders
How do i get the hdmi working from my acer5536 to my tv
Connect your HDMI cable to laptop then change the setting in audio output to HDMI digital output
For toggling the display you need to press the Fn and F5 together
If you have sounds already playing on the laptop, then you must switch your default to the HDMI then go and re open the program ie itunes. Any other program playing sounds on ur laptop speakers will continue to play through the lap top speakers...
On VISTA do this
Right click your screen
go to personalize
on the left there is an option "connect to a projectror or external display"
Click the speaker picture, and set the default to HDMI by right clicking it and selecting make default.
Close your media programs, and then re-open them and hit play..
Apr 26, 2010 | Acer Aspire 5536-5224 Notebook
No sound
Go into your sounds settings Control Panel> Hardware and Sound (on Xp its just sound)> sound> You should have 4 types of speakers available. I have Digital Output Device (HDMI) Speakers Realtek Digital Output Realtek HDMIOutput my default was the HDMI and i changed it to speakers and then my speakers worked.
Hope this helps ^^. Please don't forget to rate, Thanks
Feb 26, 2010 | E-Machines T3504 PC Desktop
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Hdmi audio not working when conected to tv
Follow these steps to change the audio output settings for the HDMI option.
  1. Follow steps 1 through 8 above.
  2. From the Windows Vista™ default Start menu, click Control Panel.
    View Picture
  3. In Control Panel, using the default Control Panel Home setting, click Hardware and Sound.
    View Picture
  4. In the Hardware and Sound window, under Sound click Manage audio devices.
    View Picture
  5. In the Sound dialog box, click to select Digital Output Devices (HDMI).
    View Picture
  6. Click Set Default, and then click OK
    View Picture
Note: The default audio setting for your notebook is Speakers / Headphones.
You must change the audio output back to the Speakers / Headphones option for the computer to once again be able to use the internal speakers and headphone jack.
Sep 24, 2009 | Gateway T-1620 Notebook
32 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
