Question about Kenmore Elite 45986 Front Load Washer
DL flashes over and over
Ok my kenmore elite front loader blinks DL DL DL then occasionally F F F, beeping along with it . it pretty much locks the door so i cant get in then out of no where it will work after 20 min or so of shaking it or preesing random buttons ,this time is the longest it continued for please help me.
  • 262 Answers
Unplug machine for 2 minutes this will reset the computer if problem continues look behind bottom front cover and there is a tech sheet that will tell you what the f code is the DL code is bad door lock assembly. it could be the main control (mother board throwing you these codes) Ive seen this happen before
Posted on Dec 19, 2007
    Problem Solver:
  • 6 Answers
Unplug your machine, remove the top panel, and recheck all the wiring is connected. Sometimes it jiggles loose from the machine's vibration. Hope this helps! It worked for us!
Posted on Jan 02, 2008
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
I own a kenmore elite front loader and it has quit working. When I set it 2 wash it only beeps and flashes dl and f. I had a technician look at it over 6 months ago and he said I needed to replace the...
Possible causes:
Door lock mechanism is broken or removed from door.
Door switch/lock unit failure.
1. Check door switch/lock unit.
2. Check the wire harness connections of the door switch/lock unit to the Central Control Unit (CCU).
Try these sites for spares:
May 24, 2010 | Kenmore 44102 Front Load Washer
Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Nov 04, 2009 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Dl flashes and won't restart
Hi. Without model # I can't be certain but, (UNPLUG machine) if you remove the panel under the door and reach up along the right side of the tub, you can feel a little lever with a lood on it to unlock the door so that you can atleast get your close out. It sounds like the door switch has gone bad.
I hope this helps. Please let me know.
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
758 people viewed this question
Sal De
 Brian Main
Brian Main
