Question about Dryers
Whirlpool LGB6300PW0 gas dryerdried one load, but
Whirlpool LGB6300PW0 gas dryer dried one load, but would not start when the next was put in. Allowed to cool and has power but will not start.
  • 304 Answers
The problem you describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
The following process will allow you to test the thermal fuse and replace it if you find it open.
Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again. Operating any dryer in a closed room with the door closed may cause this problem.
Posted on Sep 20, 2009
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Where can I find the glowbar ignitor on whirlpool LGB6300pw0 gas dryer?
Try this link it should help Typical igniter replacement You can also enter your model # there and get diagrams and illustrations of your specific model.
Dec 27, 2010 | Whirlpool LGV4634JQ Gas Dryer
Model LGR8620pw0 dried 2 loads of cothes, third load no heat. Tried the dryer next morning and it heated up.
This is likely a coil on the gas valve on its way out symptoms will often be very erratic. Replace the coils if symptoms persist.
Nov 03, 2010 | Whirlpool LGB6300 Gas Dryer
I have a Whirlpool Model LER4634JQ0 that was used to dry a heavy quilt. When the next load was put in to dry, the dryer would not start. Power to the dryer is okay. My wife tried to start the dryer today...
sounds like the dryer belt is broken or off the pully, does it make any noise at all? if yes then unplug carfully pull out and open to check belt replace if needed
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Taking apart Whirlpool dryer
below the door the panel is held onto the frame with clips. Use a putty knife to get it out yer way.77d0e23.jpg
GAS DRYER INFO
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 02, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer starts normally but no heat - burner never lites
had same thing happen.. i replaced the thermal fuse located on back papnel.. fires right up now..partis about 15 bucks at any appliance part store or online.
Aug 01, 2008 | Whirlpool GGX9868J Gas Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
Marvin
Marvin
