Question about Vehicle Parts & Accessories
While starting the car with a audiovox remote starter the car starts up and runs about a second and shuts off and tries to restart and once again it stalls other wise when you start the manually the car starts ok and runs.
    Problem Solver:
  • 9 Answers
All remote start alarms must see that the engine is running usually from a coil sense wire this is obviously not connected as your alarm keeps trying to restart
Posted on Sep 21, 2009
I have an autopage remote starter that worked just fine until I replaced the battery in my vehicle. The remote still works, everything still works except it runs for about a minute, shuts off, restarts,...
sounds like security system is keeping it from running. try this. disconnect the battery again. lock the drivers door with the key. reconnect battery, unlock drivers door with the key and try and start the car with the key. does this work?? ok now shut car off and lock it and try remote starter. hope it works it just might
Dec 03, 2017 | Cars & Trucks
Remote start starts car and dies off after few seconds
try having the cpu reset using a code reader as you may have two systems operating in conflict that is causing the problem.
Jul 29, 2013 | Audiovox Prestige APS997C Alarm/Remote...
My preinstalled remote starter on my truck has a combination/sequence that the dealers salesman could not get roght bit twice to start pickup. im looking for fimiliar combination/sequences that my seem to...
If you have to press the vehicle's door lock AND the remote starter button...something is definitely wrong with the installation. If the prestige is a one button unit, try pressing the button twice within two seconds to start vehicle (press...thousand one, release, press...thousand two,release) this is the default setting.
Aug 05, 2012 | Prestige Remote Start
How do i use the auto start
To operate the remote starter, press and release the green trunk/key button on the remote twice within two seconds like so: press (thousand one), release. press(thousand two), release. Wait. If you press the button too fast the unit will only read it as one, especially at greater distances and, you may actually start the car and shut it down before it even starts.
Jul 24, 2011 | Car APS997A Two-Way Remote Start and...
HAVE A PRESTIGE APS686T REMOTE START ON A2003 FORD FOCUS.HAD 2 NEW KEYS PROGRAMMED. THE REMOTE START FLASHES MY THEFT LIGHT AND WILL NOT START. HOW DO I PROGRAMM THE PRESTIGE TO MY KEYS.
When you had the new keys programmed, the bypass was erased. More than likely, it was a key. Try this: put the first of the two new keys into the ignition, turn the ignition on. The theft light will light up, then go off. Immediately remove the key and put the second key into the ignition. Turn the ignition on, the theft light will come. When the theft goes out remote start the vehicle with the remote, quickly remove the key from the ignition. If the vehicle starts let it run for a few seconds and then shut the remote starter down with the brake. Wait a few seconds before testing the system.
If the above programming does not work the first time, try it again. It may take a few attempts because the process is time sensitive. You CANNOT allow too much time to pass between switching the keys.
Jun 01, 2011 | Prestige APS686T Remote Start and Keyless...
Cant remember how to use the remote
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
Jan 15, 2010 | Prestige Remote Start
I have a remote car starter on my 2004 chryler Town & country van. The care will start then sut off after a few seconds then start again and shut off it does this 3 time than will not start from the...
The 2004 Town and country has a factory anti-theft immobilizer which uses a chip in the key. Without bypassing the immobilizer the vehicle will not run (the anti-theft disables the electronic furl pump). Is the factory security light on the cluster flashing when you try to remote start? if so, Re-check the bypass unit that was installed with the remote starter, the transponder should be mounted at the ignition switch, it could of slipped off. It is possible that it has lost its programming or even failed completely.
Jan 10, 2010 | Audiovox Vehicle Parts & Accessories
Remote starter does not work after the battery change. How to reprogram it? Audiovox ID:BGAAV2TF
Turn key on and press valet button 3 times then press butoon on remote.Turn key of and thats it
Nov 14, 2009 | Car APS921 Remote Starter - Keyless Entry
Car will start when the engine is cold but not when heated.
it sounds like a bad starter drawing on the car and once the starter gets hot then the selonoid will not work and if you have a remote starter on the car remove the fuse and try that to see if there is a short in the remote starter
Mar 07, 2009 | 2001 Mercury Sable
Vehicle Parts & Accessories Logo
197 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
