Question about Dual XNP653 3-Way illumiNITE Speakers Car Speaker
I need a wiring diagram to hook up a set of dual illuminite speakers in my car
    Problem Solver:
  • 7 Answers
Check out www.The12volt.com
They have all kinds of wiring diagrams. Be careful.... Car systems are designed to handle certain number of speakers and resistance (ohms). Hooking up more speakers without the proper amplifiers can damage your cars radio.
Posted on Nov 04, 2009
I just purchased the dual xinbp210 and don't know what size amp i need?
  • Enclosed subwoofer with dual 12-inch speakers; measures 27.5 x 14 x 15 inches
  • illumiNITE technology constantly illuminates the speakers with blue LED lights when in use
  • Handles 600 watts RMS power, 1100 watts peak power
  • Carpeted enclosure, plexi subwoofer viewing window
  • Dual 12-inch Low-Q optimized dri
Mar 26, 2015 | Cars & Trucks
How to connect the 12 volt DC to the illumination lights from the tweeter
1) light have 2 wire R./B.
take R n connet with other B .n 2 wire r there two join too dc okk/............
Sep 07, 2009 | Dual XNP653 3-Way illumiNITE 6-1/2''...
I have a dual XIA3145 580 watt amp that keeps blowing fuses
Generally, this indicates that there's at least one shorted output transistor.
Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still blows the fuses, the amp almost certainly has shorted output transistors and will need to be repaired.
I'd recommend using two 10 amp fuses. The amp will power up with 10 amp fuses if there is no problem. If there is a problem, there's less of a chance of doing more damage by using the 10 amp fuses.
Let me know if you have any other questions.
babin_perry@yahoo.com
Sep 04, 2009 | Dual Electronics illumiNITE XIA3145 Car...
Blue illumination doesnt work
unscrew the plexiglass and try to get to the light and mess with it to see if it shook something loose, if that doesnt work, you might have to buy a new light....hope this helps!!
Mar 21, 2009 | JC Whitney - Dual Illuminite 12" Bandpass...
How do i wire 10' kicker cvr
dual 2 or dual 4
dual 2 wire vc's in series for a 4 ohm load each. Hook each speaker seperate channels on the amp.
dual 4 wire vc in series for an 8 ohm load each. Hook both + to the right + on the amp and both - to the left - on the amp. or
dual 4 wire vc in parallel for a 2 ohm load each and hook each speaker to seperate channels on the amp.
Dec 18, 2008 | Kicker CVR12 Car Subwoofer
Iluminite Speaker Instalation 12v DC power
There is 12+ going to the power window switch if you have power windows, you could tap off of that. It's already inside the door, no routing needed. Use continuity test to find ground. Also hook up a seperate switch on the door to turn them on or off.
Oct 17, 2008 | 1998 GMC Jimmy
Dual SBX554
POWR TO BATTERY FOR WHAT?DOES THE SPEAKERS HAVE AN AMPLIFIER? NEW RADIO? SPEAKERS ALONE ARE NOT CONNECTED TO BATTERY ,UNLESS THEY ARE POWERED SPEAKERS,USALLY SUB-WOOFERS HAVE THEIR OWN AMP.iF YOU ARE CONNECTING A AMPLIFIER START WITH A FUSE SAME SIZE AS THE AMP,CONECT 1ST TO THE BATTERYTHE TO THE FUSE RUN A SIFICIANT GAUGE POWER CABLE TO THE AMP.GET THE GOUND FROM A PART OF THE CHASSIS CLOSE TO THE AMP,ALSO SAME SIZE OR LAGER GAUGE WIRE.THEN YOU HAVE TO RUN A REMOTE SWICH WIRE FROM THE BACK OF THE RADIO TO THE AMP.iF RADIO DONT HAVE REMOTE ,CUT INTO THE POWER ANTENNA WIRE .RUIN YOU RCA CABLES TO THE AMP AND WIRE YOU R SPEAKERSMbUT FIRST DISCONNECT YOUR GROUND FROM THE BATERY MOST IMPORTANT.ANY '?'S.WRITE BACK RATING PLEAse.
Oct 26, 2007 | JC Whitney - Dual Blue Led Speakers Car...
How to install LED to car battery
power for what? what do u want to connect to battery?
Car Audio & Video Logo
380 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
