Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
Aquos 13b4u this is a 2-3 year old set. All cable channels 1-28 sound volumes are equall except for 10 and 11. 10 and 11 only provide half the volume of the others.This is a new problem. Does this indicate a board failure or?.....
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most likely a cable box problem. You would see a consistent problem with a TV failure.
Posted on Feb 05, 2008
Why can't I get the same volume out of channels 5/7 & 7/8 as I do from 1,2,3,4?
Those stereo channel inputs are at line level rather than instrument level.
Aug 24, 2015 | Yamaha EMX312SC Powered Mixer 300 Watt...
Midland lxt380
Hope this helps... try swapping battery pack and antenna. Try also all available channels path... Goodluck.
Mar 19, 2014 | Radio Communications
Samsung flat screen T.V with sound problems.
Sounds like the issue is with the set top box of your cable or direct tv provider. Please swap that receiver for the equivalent or a more updated version.If the problem persists. Verify that all inputs on television is correct. It should match. Output of source( digital receiver,dvd player) to Input( television ). Make sure all is secure. Good luck
Jan 31, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have a terrible time with the volume. One time
Every station is permitted to set their own volume based on federal guidelines. Ad space pay more money to turn up the volume so that when the commercials come on that they are screaming at you so you look at the TV.
Your brand of TV has an equalizer system to control the different Hz levels of sound. The following is a link to the manuals for the Hisense brand of TV:
http://tv.manualsonline.com/manuals/mfg/hisense/hisense_flat_panel_television_product_list.html
Under the Audio part of the menu system, there is a section called Equalizer. While the TV is on and functioning, change the settings until you are comfortable with what you are hearing.
Also, some cable systems allow you to change the settings for your audio. Since I dont know who you use, I can not comment on if they provide this service.
If I have helped you, please rate me as so. It allows me to help others.
Aug 06, 2009 | Hisense Televison & Video
Have a Motorola XV2100 VHF two way radio that works well except the volume control must be turned all the way up so you can hear it. The radio is about 5 years old and was never used very hard. Even with...
Hi Ed,
The VHF radio that is quiet, does the Speaker have a rattle, even very slight? if so that speaker could be faulty, and /or also does the volume control make a scratchy noise when you rotate it?
if so this could be faulty try some CRC down the shaft let it sit for say 15 minutes then rotate the conrol from stop to stop a few times.
To service--- well, would pay you to get a quote first from one or more service establishments if repairs are required.
Good luck,
John.
Apr 06, 2009 | Motorola XV2100 (1 Channel) 2-Way Radio
Can you hook something up to the aquos to get louder volume?
ARE YOU HOOKED UP TO A CABLE BOX? IF SO THERE IS A VOLUME ADJUSTMENT ON THE CABLE BOX TO HELP OUT. IF NOT I'M AFRAID YOUR ONLY SOLUTION IS TO HOOK UP A SURROUND SOUND SYSTEM.
Feb 03, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Jan 10, 2009 | Televison & Video
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Volume issue
Very loud it never gonna be. It's a tv with very small speakers, but I have a lot of customers who complain about that and I checked first the signal source. Sometimes the sattelite receiver or cable box give a sound not so good. The best way to check it is to plug something (an antenna or just a 2 inch wire) in the coaxial plug to see if on the tuner is the same sound. I bet is gonna be stronger.
Dec 29, 2007 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp LCD LC-46D64U
Try resetting the TV. Here's how to do it - Unplug the TV's power cable. Keep the Channel Down and Volume Up buttons on the TV pressed and plug the power cable back into the outlet. You will hear a click when you plug it back in if the reset is successful. Hopefully this should restore your video and audio.
Dec 25, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
53 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
