Question about Kenmore 13593 Stainless Steel Built-in Dishwasher
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of household water pressure. I removed the inside pieces down to the shaft and cleaned it out thoroughly. Could there be a worn out piece that is letting the water bypass the spinners? Are these parts available aftermarket?
  • 4,356 Answers
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Posted on Sep 20, 2009
Why do dishes on the top rack feel dirty after washing?
probably not getting enough water pressure in the top section of the machine to was properly ( dirty spray bar jets /nozzles)
do a machine clean using good quality recommended agents
A major problem that occurs with dish washers is the failure to rinse off the items to be washed before installing in the machine
this refuse then blocks up the jets and nozzles in the spray bars and stops the pump from reaching full pressure.
May 14, 2015 | Frigidaire Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
It simply washes poorly. Leaves soap film on dishes AND shellacs food to dishes instead of cleaning them. I can put in just thoroughly washed dishes and they come out dirty! It's amazing. I've done...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Kenmore 13593 Stainless Steel Built-in...
I have a kenmore ultra wash quietguard 3 . It fills but not enough to cover the heating coil. It washes poorly and leaves schmutz on the dishes. I have checked all the sprayers. They are not clogged. ...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Apr 22, 2011 | Kenmore Dishwashers
Kenmore ultra wash dishwasher has not enough water presure to turn the upper level water jets. Any sugestions?
Remove the sprayer and clean the spray nozzles...they are probably clogged with dirt and excessive dishwashing soap. Mine actually had small chips of my plates in it!
Dec 17, 2010 | Kenmore Dishwashers
Hi- my dishwasher is not cleaning properly. It seems to get enough heat, there is no noise, etc. About a week ago, it just stopped cleaning. It will go through an entire cycle and the cups are always...
Probably a blocked spray arm (part that spins around). Remove each of the spray arms and check and clean all the holes as this is where the water sprays out from to clean the dishes and glasses. When they are blocked you get poor wash results.
Hope this helps
Jun 09, 2010 | Bosch SHU5315UC Dishwasher
Want to replace dishwasher panel with stainless steel
I'm not sure if that replacemetn part would work, but I know you can get cheap stainless panels and faux stainless options at applianceart.com. They have colors, textures, seasonal, designs, and stainless steel. You can choose between faux stainless (as seen on HGTV and the Today show) or regular stainless metal. check out www.applianceart.com
Jan 19, 2009 | Kenmore 13593 Stainless Steel Built-in...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Kenmore 13593 Stainless Steel Built-in Dishwasher Logo
207 people viewed this question
Top Kenmore Dishwashers Experts
vince
D. E. Hev
gbob59
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
