Question about Kenmore Washing Machines
I have taken apart the kenmore gas dryer to change the belt. But a part fell off when I removed the drum. I need a picture of the inside of a gas dryer model 70202990
  • 4 more comments
  • defalcoe Sep 20, 2009
    I am talking about the part that gives tension on the belt. The picture you sent me is not very clear
    It is the idler pulley that I don't know how to affix it to the dryer. It fell off when I removed the drum. I need a large picture of the idler pulley and how it is installed.
  • defalcoe Sep 21, 2009
    It is only a picture of the part. But it doesn't show how it is installed .
    I need to see a picture of how it hooks on the floor. I went to the blog you told me to. It only has a picture of the part. That is no help at all.
    I see plenty of pictures of the part. But none of you show me exactly how it hooks into the floor. I need to knoe where and how it hooks in.
    I am told there is no such address.
  • 220 Answers
That would be the Idler pulley it hooks into the floor I'm including a link to what it should look like just copy and paste it into another window and you'll see what it should look like.
http://www.applianceaid.com/images/threadbelt2.jpg
Posted on Sep 21, 2009
  • 2 more comments
  • TomZS Sep 21, 2009
    Try this one
    http://www.partselect.com/Blog/images/pa...
    The idler only hooks into the floor nothing holds it in place except the tension of the belt.
    The picture you looked at is of the part installed with the belt in place,the idler arm and pulley assy only hook into the floor there are no fasteners to hold it in you have to hold it in place while you thread the belt around it,once the belt is on it stays in place.
    Here I found a video that may be of use to you.
    http://www.youtube.com/watch?v=9dd1Ac4_p...
    President:
  • 1,865 Answers
Go to the following link. There are links to drawings in the subcomponent list. You can look at those for assistance
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=sGCLQdKp3ehTnwa0bi0FRQ**.shcapp3205?modelNumber=110.70202990&pop=flush
Posted on Sep 20, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please see these pictures for your dryer--
This will also help--
Please check which fell down & re seat it back by looking at the pictures.Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Sep 20, 2009
    Hi
    You can click the pictures to Zoom in, the part you want to install is the idler pulley i think. Please follow this procedure to re-install the belt--
    1-- Prepare for replacing the dryer belt by lifting the
    lint-screen cover on the top of the dryer. Then remove the lint screen. Skip
    this step if your lint screen is inside the door. Remove the 2 Phillips screws
    inside the door instead.
    2-- After removing the lint screen, lift the cover and
    remove the screws that hold the lint-screen housing to the dryer top.
    3-- Slide a putty knife between the front panel and the top
    near a corner. Lift the corner and repeat on the other side.
    4-- To remove the lower panel, insert the putty knife
    between the panel and each side. Then twist to release clip.
    5-- Place a few wood
    blocks under the drum. These support the drum when the front panel is moved
    away from the sides.
    6-- Loosen the screws that secure the bottom of the front
    panel to the dryer sides. Do not completely remove the screws.
    7-- Remove the screws that secure the front panel to the
    dryer sides at the top. These are accessed from the inside of the cabinet.
    8-- Lean the front panel away from the sides and slip the
    new dryer belt over the drum. Then resecure the front panel.
    9-- Check that the lip on the back of the dryer drum fits
    properly against the seal on the rear bulkhead of the dryer.
    10-- Locate the original position of the old belt, and slip
    the new belt in place. Keep the grooved side of the belt down.
    11-- Push the idler pulley toward the motor and loop the
    doubled-up belt around the idler pulley. Slip belt around motor pulley.
    12-- Rotate the drum counterclockwise a few turns to check
    belt tracking. Then replace remaining components and test run.
    Thanks
    Rylee
My dryer is making a loud squeking noise once it gets warmed up. Does anyone know what could be causing this?
yes could be the pulley or the rollers on the inside you would need to be able to open the unit top cover and inspect the belt on the inside and underneath the drum if you have never taken a dryer apart before i do suggest you call a technician hope this helps
Jul 21, 2010 | Kenmore Elite HE4 Electric Dryer
Tip
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryerhttp://www.youtube.com/watch?v=CFnXwmUb4f4
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door. http://www.youtube.com/watch?v=rtATa0a28bE
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel rhttp://www.youtube.com/watch?v=zpUqCrLaI7g
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
http://www.repairclinic.com/PartDetail/Belt-Drive/1246110?modelNumber=LDE8424ACE#repairHelpVideoTabs
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
My gas dryer will not turn the clothes drum
The drive belt that turns the drum has broken off or fell off. Sears does sells these belts in a kit forn including the tensioner pulley. Purchase that. The top and front panel will need to come off to do this repair
Jul 11, 2010 | Kenmore 62602 Electric Dryer
The belt around the drum of my dryer broke. i have a new one just need some tips on puting it on. Also when i pulled the drum out there was a white/clear piece, round in size, and a metal clip laying on...
don't know what the pieces are that you found on the floor of dryer,check the front panel for the clip,might have popped off when you took the dryer apart or these things fell out of clothing that were put into dryer.now the belt,rap it around the drum with the ridges touching the drum, smooth side up.stick the drum in place and spin it a few times till the felt in the back is lined up and the rollers are lined up on the drum,stick your head inside the drum and hold the drum up with your shoulder,just pinch the belt together and pull it under the pulley and attach it onto the motor shaft,that's it.picture your pants belt floded in half,around four inches from the folded part pinch the belt together and you'll have a loop on the end,your fingers are the bottom part of the pulley and the loop end is the part of the belt that connects to the motor shaft.hope this helps,let me know how you make out
Jun 25, 2010 | Kenmore Dryers
Is there a procedure to change belt? Also 1 (left) drm roller
No set procedure. Idler wheel is a common failure on Amana Dryers. Remove front panel and front bulkhead, from there you can remove belt from idler and pull drum from unit. The screws are a 5/16" hex head. While you have the unit taken apart, ensure you vacuum the interior cabinet and make sure your vent out of the house is clean, this will help prevent a house fire.
Mar 28, 2010 | Amana ALG331RAW Gas Dryer
How remove front panel of frig gas dryer faqg7077kw
Hello there:
Here is how to disasseble the dryer
White/Westinghouse - Frigidaire style dryers- How to take apart....
White/Westinghouse, Frigidaire style dryers ( some 417.######## Kenmore dryers ) - How to take apart:
Disconnect power first In order to test and effect repairs on any product, you must be able to disassemble and reassemble the appliance. So lets start with disassembly on this dryer. Unplug the dryer. Get the top up by pushing in on 2 clips on either side as shown in this picture. We need to remove the front of the dryer next. There are 2 or 4 screws inside at the top on most of the older dryers that we need to remove. Once the screws are removed, you can pull forward on the front and lift the complete front off the 2 clips on the bottom of the dryer. Unplug the door switch wires and set the front aside.
if you need to further dissassemble it follow the next steps
Next step in disassembly is to remove the belt from the idler and the motor pulley. This is done at the rear of the dryer. Remove the 2 screws holding the inspection plate on the left rear of the dryer. Remove the plate. Look carefully at how the belt threads around the motor pulley and idler pulley so you can replace it. Remove the belt from the motor pulley. Return to the front of the dryer, grasp the belt in one hand and the front of the drum in the other hand. Lift up on the rear of the drum and pull forward with the other hand. There is a ball on the rear of the drum that rides in a socket located in the center of the back of the dryer. You are lifting the knob up and out of the socket. Look in the center of this picture for the socket. You have taken the dryer far enough apart at this point so that you can accomplish any repairs needed on this style dryer. It is not necessary to go this far for all repairs, but if you need to disassemble, you have the information.
Jan 09, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer squeek when running
A squeak is usually a roller that needs grease. It's best taken care of, you don't want the roller to wear out. Take the dryer apart, remove the drum and use heat resistant grease on the roller shafts. Note how the belt goes so you will be able to get it back on. You may need snap ring pliers to get at the roller shafts.
May 14, 2009 | Kenmore 74742 Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore Dryer Drum is very loose and noisy.
It sounds like one of the rollers has a bad bearing. You will need to take the front off the dryer, unhook the belt, and remove the drum to check the rollers.
Nov 20, 2008 | AEG T57800 Electric Dryer
Washing Machines Logo
99 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
