Question about AOC L24H898 24 in. LCD TV
Buttons locked on AOC 24'
I have the same problems with the AOC LCD 24' TV. The tv turns on, and then its says "no signal" When buttons are pushed it says "Butons Locked" I have tried everything, It seems to be stuck in AV mode, however, when DVD player is turned on, it only plays audio and no video. PLEASE HELP!!! I called cuustomer service and left a message. Awaiting answer.
  • christens746 Sep 20, 2009
    you can't do anything..every button you hit says "button locked". therefore, you can't run a channel scan using the remote or using the buttons on the tv itself.
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Posted on Sep 25, 2009
  • 834 Answers
You need to run a channel scan useing your remote run set up like when you first bought the unit
Posted on Sep 20, 2009
    New Friend:
I have the same screen "Buttons Locked" tried the solution above and still nothing,I cannot run a scan because the buttons are locked and when I held the volume buttons down the only thing that did was allow me to turn the volume up and down.Tried holding other buttons and unplugging the tv ..still nothing Please help
Posted on Jan 08, 2013
My aoc l24h898 lcd tv led light turns blue but then turns red in seconds
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 17, 2015 | AOC L24H898 24 in. LCD TV
How do you reset an AOC tv ?
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
May 03, 2014 | AOC L24H898 24 in. LCD TV
Somehow I am getting "button locked" on every button but the power button. Does anyone know how to fix this??
A factory reset on several AOC models can be performed by unplugging the TV for 5 to 30 minutes. When it comes back on it should be reset to factory defaults and ask to do a channel scan. You have somehow enabled the so-called childproof or "Bar mode" of the TV which deactivates the panel buttons so kids (or patrons) cannot mess it up.
Sep 08, 2013 | AOC L24H898 24 in. LCD TV
Service mode aoc lcd tv
This sounds like a common problem on these TVs. Try a factory reset:
3. *A small screen should appear in the top left part of the screen.
If this still does not work, perform steps 1-3, but when you get to step 4, select "EEPROM Init". Then steps 5 and 6 to power it off and back on.
Mar 05, 2012 | AOC L24H898 24 in. LCD TV
AOC tv menu locked how to unlock
The TV is locked.. The message is Bottom Locked.
Jan 09, 2012 | AOC L22W898 22 in. LCD TV
My screen is just grey, no picture and when i push a button (any button except power) it says "button locked"
Hi there , maybe to late by now but sounds like the panel lock is on you can only remove it by using the remote and going into the menu and turning the panel lock off .
Feb 04, 2011 | AOC L26W861 26 in. LCD TV
No tengo menu en lcd aoc L24H898
mi televisor se quedo azul se ve la imagen azul y se quedo sin sonido al presionar los botones dice " button locked"
Dec 15, 2010 | AOC L24H898 24 in. LCD TV
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
AOC L24H898 24 in. LCD TV Logo
2,207 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
