Question about FTP Software TRI-ASA2120 Router (TRIASA2120)
I do not see the download commandwhen I click right on the mouse. Why?
How do you copy paste
I just select the part I need and move it from the internet to an open document on the desktop, since I run Linux Mint I had to learn how to do this to get my Terminal command correct
Nov 22, 2013 | Computers & Internet
Tip
Fix sound problem in Ubuntu
Off a fresh install of Ubuntu (GNU/Linux) there is often a problem withthe sound not working right away. I have found a simple fix for thiswhich does not require additional drivers or any downloading. Istarted with a fresh install of Ubuntu 9.10 Karmic Koala.
First, right click on the speaker icon at the top near the clock and select Sound Preferences.
Turn up the "Alert volume" to about 75-100%, make sure it's above half,the default is 50%. Also make sure the Output volume is near 100% also.
Now this next step is where the magic happens:
Then tab over to the Hardware tab in the preferences. At the bottom of this tab you will see "Settings for the selected device:" and below that is "Profile:" This is where you will mouse over the "AnalogStereo Duplex" flick the mouse wheel up once so it reads "Analog StereoOutput" and then flick the mouse wheel down again back to "AnalogStereo Duplex". Close the properties now, and the sound should work. (If you don't have a mouse wheel, just left click on it to change the selections.)
Also from time to time, something goes down with pulseaudio (the sound) and simply running this command in a terminal window will bring it back to life.
This is the command:
sudo killall pulseaudio
All this command does is kill all processes using the audio, therefore refreshing the audio devices and freeing it up. This does not remove any packages or drivers, just stops all processes using audio. If you are playing a song in Rhythmbox, you will have to restart the song again, no problems there.
This command I have tested with Ubuntu and Mint and works with both, I imagine it works in all Debian-based Linux distributions. I hope you found this information helpful, if so please rate me with the blue thumbs!
on Jan 01, 2010 | Canonical Ltd. Ubuntu
P1g41u motherboard keyboard and mouse not working
make sure the batteries are inserted correctly and have charge if applicable
usually located on the underside of the mouse there might be small plastic sticker with a phillips head screw under it rub your fingernail over the top to see if it has a screw
or make sure the usb device is properly inserted for wireless
the usb or Ps2 connection are secure with a dust free connection
or it might be the usb for wireless mouse or lead connecting to the usb port or even a faulty mouse
if this does not fix the problem
restart you computer tap the f8 key repeatedly to enter safe mode where the only things working will be your keyboard and mouse allowing you an attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
select safe mode
click start control panel administrative tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver rollback driver or uninstall also
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 arrows >> then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start control panel keyboard hardware make sure you have the right keyboard selected
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver
hope this helps
http://www.microsoft.com/hardware/download/download.aspx?category=MK
complete range of drivers
Aug 10, 2012 | Computers & Internet
SEARCH GOOGLE USING E-SPEAKING
These commands are built-in. You do not have to add or program them.
Working with Applications
Say... Open Word
Open Excel
Open Email
Open Powerpoint
Open Internet
Open Notepad
Close Application
Close Window
Close Document
Scroll Down
Scroll Up
Start Word
Start Excel
Start Email
Start Powerpoint
Start Internet
Start Notepad
Minimize
Maximize
Scroll Left
Scroll Right
Browsing the Web
Browse the web using the following commands: Open Internet
Google Website
Yahoo Website
Altavista Website
MSN Website
eBay Website
e-Speaking Website
Go Back
Go Forward
Refresh
Dialog Commands
Sometimes a program will simply ask you for a yes or no answer to an alert box or dialog. Yes
No
Cancel
Affirmative
System Commands
You can control when e-Speaking is "listening" to you using these voice commands. Standby
Resume
Stop Listening
Begin Listening
Hello
Computer
Listen to Me
Add a New Command
Add Mouse Click
Moving the Mouse
The Mouse Movement option has to be checked on the Mouse menu. Mouse Left
Mouse Right
Mouse Down
Mouse Up
Faster
Slower
Stop
Mouse Clock One
Mouse Clock Two
Mouse Clock Three
Mouse Clock Four
Mouse Clock Five
Mouse Clock Six
Mouse Clock Seven
Mouse Clock Eight
Mouse Clock Nine
Mouse Clock Ten
Mouse Clock Eleven
Mouse Clock Twelve
Slide Left
Slide Right
Slide Down
Slide Up
Mouse Buttons
Select
Double Click
Right Click
Properties
Drag Item
Drag File
Drag Object
Release Item
Release File
Release Object
Mouse Jump To
Mouse One - Top of Window
Mouse Two
Mouse Three
Mouse Four - Middle of Window
Mouse Five
Mouse Six
Mouse Seven - Bottom of Window
Mouse Alpha - Left of Window
Mouse Beta
Mouse Charlie
Mouse Delta - Middle of Window
Mouse Echo
Mouse Foxtrot
Mouse Golf - Right of Window
Editing Commands
Doing some word processing? These commands may help perform common Windows functions. Select All
Edit Copy
Edit Paste
Edit Undo
Edit Delete
Edit Find
Delete Line
Find
Search and Replace
Moving the Text Cursor
These commands may help navigate documents. Left Arrow
Left One
Left Two
Down Arrow
Down One
Down Two
Right Arrow
Right One
Right Two
Up Arrow
Up One
Up Two
Page Up
Page Down
Beginning of Line
End of Line
Beginning of Document
End of Document
Simulating Keys
Enter Key
Home Key
End Key
Spacebar
Escape Key
Delete Key
Backspace Key
Tab Key
Dictation
Start Dictation
Stop Dictation
Standby
Resume
Train Word
Show Commands
Dictation - Editing
Delete that Phrase
Delete that Text
Delete Last Phrase
Delete Last Text
Strike that Phrase
Delete Last Word
Edit Copy
Edit Paste
New Line (inserts a line)
Next Line (inserts a line)
New Paragraph (inserts 2 lines)
Next Paragraph (inserts 2 lines)
Select All
Delete Key
Backspace Key
Reading Commands
Read All Text
Read Selected Text
Stop Reading
Pause Reading
Resume Reading
Skip Ahead
Skip Back
Read Faster
Read Slower
Phonetic Alphabet
You must really like using voice if you are into the Phonetic Alphabet. Alpha
Bravo
Charlie
Delta
Echo
Foxtrot
Golf
Hotel
India
Juliet
Kilo
Lima
Mike
November
Oscar
Papa
Quebec
Romeo
Sierra
Tango
Uniform
Victor
Whiskey
Xray
Yankee
Zulu
Feb 05, 2011 | e-Speaking
I can't open my yahoo mail it keeeps coming up that they can't display the web page
I will assume that you are using Internet Explorer to get to Yahoo.
Try downloading and installing Firefox browser, or Google Chrome browser, both free small downloads.
If this fixes the ability to get to yahoo, then cool.
If not then do this:
Vista or Windows 7:
Find the command prompt icon in all programs.
Right mouse click on it an click run as administrator.
This will bring up a command prompt window.
Type the following:
netsh winsock reset
Press enter.
Restart computer.
Windows XP:
Start run CMD, click ok, then type the following:
netsh winsock reset
Press enter
Restart computer.
let us know if you have success or not.
Good Luck!
May 06, 2010 | Toshiba Satellite P105-S6104 Notebook
Quick instruction to install leeds asi/66887 wireless mouse
You need installation disc, if you have lost the CD, than go to this site Driver Update Software for XP Vista 7 8 and download their update tool. I hope I helped.
Micky
Feb 12, 2010 | Microsoft Wireless Notebook Optical Mouse...
Acer 5517 mouse pad does not work. is it just a
First you should check if the button that enables and disables your touch pad is on. It's the button left to the power button.
Feb 10, 2010 | Acer Aspire 5500 5570-2609 Laptop
Logitech V22 optical mouse working funny
You probably need the mouse software. Contact Logitech and follow their instructions.
Dec 02, 2017 | Logitech V220 Mouse
Usb issue
Do you have a ps/2 keyboard/mouse? Or a usb->ps/2 adapter. I'd say boot up normally and log in with the ps/2 keyboard/mouse. Then, from device manager, right click everything under USB and such and uninstall. Then right-click your computer name in the device tree and scan for changes.
Feb 16, 2009 | Dell Dimension C521 PC Desktop
Will not play downloaded videos or movies
I still cannot reach you.
I will go offline now, whatever question you have, ask here, I will answer in the next 24 hours.
Here again yopu have the solution:
The chat is not responding follow mmy instructions here.
Download one movie on the desktop.
Click right mouse button on the movie on the desktop and chhose the last command that is properties.
On properties box ther is a change button, click it and set it to internet explorer.
Nov 22, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
Top FTP Software Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a FTP Software Computer and Internet Expert? Answer questions, earn points and help others
