Question about Honda Pressure Washer PSI 3000
My powerwasher fell into the pool...I pulled it out immediately but now it won't start..the cord won't even pull...is it toast?
  • 986 Answers
Have you pulled the spark plug and checked for water?? Chances are if it sucked up water its Hydrolocked. Pull the plug and if you get water in the cylinder its pretty much toast. When a Hydrolock occurs valves and rods are bent. Sorry Hope this helps
Posted on Sep 20, 2009
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
My camera fell in a pool
Unless you immediately pulled out the batteries (main battery and back up battery) then the chances are that the water shorted out the circuit and it is probably beyond economic repair
Feb 06, 2014 | Canon EOS 550D Rebel T2i Digital Camera
Performance power 420 mower won't start
remove the starter assembly and then you can see whats going on like a knot in the rope or something
Aug 10, 2012 | Garden
Starting 94 timberwolf
need a new relay--probly toast--its a little plugin device near batt-chec a repair manual
Jun 17, 2012 | Motorcycles
I turn on the camera and the screen starts flashing. lenses wont come out all the way. Fell in the pool.
if it fell in the pool you wouldn't have turned it on instead you would have pulled out the batteries and place the camera in a conducive environment for it to dry for about 2hrs before turning it on......Anyway you can still try..
Jul 12, 2010 | Cameras
Husky 2600 psi Powerwasher will not start, it was only used once, in 2008. gas was left in the powerwasher over last winter. I followed the 13 steps on hooking it correctly and turning it on etc.. when I...
You may have to take out the carb and get it cleaned / air-blown out. Looks like some little valve is stuck. Also make sure you are getting enough sparks at the plug tip. If you have left it long in a damp place it may take several pulls on the cord for the engine to fire-up and run. Try spraying some WD-40 into the cylinder through the plug-hole. Then pull the cord again. After a few pulls remove the plug again, and put like a spoonful of clean 10/30W engine oil into the cylinder, and keep pulling the cord until you see some smokes at the exhaust. If the engine fires up and run a few minutes, but stops later. The engine might be out due to incorrect oil/fuel misture.
Oct 20, 2009 | Garden
I powerwashed my 02 silverado v6 and it wont crank over.
check connections at starter and junction near battery
Feb 25, 2009 | 2002 Chevrolet Silverado
Honda Pressure Washer PSI 3000 Logo
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
