Question about Garden
My westwood t3100 sparks but wont fire up??
Hi, ihave a westwood t1300 - its sparks but wont fire up, i have checked everthing i can imgine it might be but have run out of ideas - can you help.
if it helps i had it running once but when i switched it off it would'nt start again
thanks, tim
  • 62 Answers
Two ideas- usually its a fuel problem if you know your getting fire, so make sure your getting fuel, take off breather and prime carb directly, make sure mower is in neutral, foot engaged on the pedal, and you are sitting on the seat, if it doesnt start the other thing it could be is your safety shut off switches, check your manuel, but there is usually three of them, one is on your neutral shift, other is under your seat, and the other is at the pedal, hope that helps
Posted on Oct 23, 2009
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Ihave changed the crank sensor and the coles on the plugs but still the it wont give a spark.
DID YOU CHECK THE COIL PACK.........THIS SENDS A SPARK TO YOUR SPARK PLUG
Apr 15, 2014 | 2005 Toyota RunX 160i
Hi help ihave a 2,3 also with a lot of new parts i have no spark on 2 and 3 cylinders it has new coils sparkplugr wires also new injectors and ecm still no spark runs wont rev dies when you try to hit...
Hello, If you do not have a Distributor, they use position sensors to make the engine fire. If the sensor is broken or loose from one end, then the sensor will be too far away to fire all of the plugs.
Sometimes with Magnetic pickups, rust will affect the sensor and block it from picking up the turning Crankshaft or Camshaft. A mounting bolt can fall out and the sensor can hang lopsided until one side will not fire because it moved out of position.
Check the sensors and if the part they appear to scan is rusty, clean off the rust.
Check the connectors to these parts.
Dec 07, 2011 | Cars & Trucks
Ihave problem firing sistem
you need to either replace the plug, or if that doesnt work check your plug wire
Mar 09, 2010 | 1988 Nissan Sentra 2 Door
My westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Dec 20, 2009 | Briggs & Stratton Garden
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Oct 03, 2009 | Garden
Hi, I have a westwood ride on mower & the 3 bladed 36inch deck has started to whine bearings I think? Are they easy to change? special tools? parts off who? the machine is just 3 years old Thanks JT
I assume you are referring to the deck bearings. The easiest way to replace the blade drive bearings is to remove the deck from the mower. You can then easily remove the blades, clean the deck and be able to easily get to the bolts holding the bearings and pulleys in place. This is normally a straightforward repair and can be accomplished with common hand tools. You will need to purchase the parts from the dealer who sells the mower. Replace all 3 set of bearings. On a 3 year old mower ask yourself why the bearings failed. Are you washing under the deck when the bearings housings are hot? That will cause premature failure. Are you greasing the bearings regularly?
Sep 20, 2009 | Garden
Garden Logo
342 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
