Question about Drills
Milwaukee mag drill #4202 drill starts then dies right away,or wont start. has good brushes thank you
  • 143 Answers
Sounds like a fault in the winding. Sorry, service centre required.
Posted on Sep 20, 2009
Troubleshooting milwaukee magnum hammer drill half inch 5370-1 672 b no power. Cord continuity is good
The only things that would cause this are a burnt out trigger switch or the motor brushes are worn out.
Sep 06, 2016 | Milwaukee Drills
Why wont my Milwaukee impact driver work when I pull the trigger ?
If the accu says Hi I am Full on the test button , i say short REPLACE ancre(armature AND carbon brushes together. remember if you have short brushes and you are working professional every day with this tool your brushes are AGAIN be shorted in a few weeks . 4 brushes in a brushholder and be carefull with soldering on the realy expensive switch if to long heat on the contacts it will also defect . MArketing technical position numbers to buy on differend models can be possible ask your dealer for a cheaper deal because what realy needed is the armature and the brushes not that complete unit , its a milwaukee marketing option because of the price Unfortunately
23 66 1239 Switch Handle Kit
but this is a real solution
Panasonic has with this kind of Johnson brushmotor exactly the same problems with Ey 7441 model after a few years of using by heat dissipation internal thermical or not thermical shorting of wires of the armature it is highly audible by a piercing sound
14 46 2018 Carbon Brush Kit
and together with this 16 01 3010 Service Armature Assembly
look this JOHNSON kind of difference in the
changed way of wrapping armatures and the old way was good but the new way delivers more power but also heat and that will make the trouble look here the differences of the old and the new
Sep 10, 2014 | Impact Bare-Tool Milwaukee 2650-20 18-Volt...
We need a demagnetizing switch...cannot find supplier for parts
they don't sell just the switch, you would need to replace the control panel. You can go to milwaukeetool.com and find a service center/parts supplier on their site. If you have trouble finding one give me your general area with zip code and I will see what I can do to help.
Sep 14, 2011 | Milwaukee Tool Milwaukee 4210-1 aka 4262-1...
The power will not turn on checked the e-stop button and is is very loose
I am assuming that you have this tool on some steel. If so and the unit will not turn on I would think that the panel is bad. You can find the breakdown and wiring instructions for this tool by going to milwaukeetool.com and typing in your separate model number but you will need the serial number also.
Aug 15, 2011 | Milwaukee Tool Milwaukee 4210-1 aka 4262-1...
Milwaukee heavy duty hammer drill only works when pointed upwards. As soon as I point it down the motor stops (or doesn't start with the drill in that position).
could be loose connection at the switch or brush holders. You can go to Milwaukeetools.com to download a breakdown for this tool.
Aug 14, 2010 | Milwaukee Drills
4270-21 Compact Magnetic Drill Press: mag base will not hold at all...
If I'm not mistaken, these drills use an electromagnet. Start by measuring the current when the magnet is switched on, but not the drill. If you don't have a current meter, just plug the drill plus an incandescent light into a long lightweight extension cord. You should see the light dim a little when you switch on the magnet. If the light doesn't dim, you just aren't getting power to the electromagnet, and it's probably a broken wire or a bad switch. If the tool has it's own fuse, I would think it would be for the drill only, not the electromagnet.
May 06, 2010 | Milwaukee 4270-21 Compact Magnetic Drill...
When turned on in forword the buzzer comes on like the magnet is not turned on. runs fine in reverse
could be a couple things, what thickness material are you trying to drill?? Also if the for/rev buttons are jammed this could cause this, check for low voltage, usually when the buzzer does sound the magnet is not energized and it could be a faulty panel that would need replaced. this tool has a limited 5 year warranty. Let me know what you find and I will try and help more
Dec 18, 2009 | Milwaukee Tool Milwaukee 4210-1 aka 4262-1...
Mag drill will not hold strong to surface
hi first try the magnet on a clean flat piece of m/s sheet/plate 2 inches bigger than the magnetic base ,it should be very hard to remove make shure the magnetic base is clean and the beam you are drilling is paint and rust free if possible clean up the beam with a sanding disc try it make shure the cutter is sharp and use coolant a dull /blunt tool will need more force a good tool almost cuts with no effort on the handle if you are drilling upside down or on the side of the beam NOmagi drill will do this without extra support silk090
Jan 08, 2009 | Milwaukee Tool Milwaukee 4206 - 1...
2 Milwaukee 18VDrills stopped working - NEED repair help
This may not be as easy as you think. The first one my have trouble with the trigger switch, but it could be the motor. Without checking continuity, or replacing them individually you will not be able to tell which one is bad.
Another problem could be the brushes. That is what is most likely wrong with the 2nd one. Remove the 2 black screw caps on the rear of the drill, and remove the carbon brushes. Do they look worn? If so they will need to be replaced. If this is the case the motor may be breaking down, and wearing the brushes down too fast.
The good news is that Milwaukee Tools, offer a 5 year limited warranty, If you have a receipt, or can read the serial number. Take it in, or mail it to a service center. They will take care of it for you if they are less then 5 years old.
Dec 29, 2008 | Milwaukee 0822 24 V18 Driver Drill Kit
Drills Logo
124 people viewed this question
Top Drills Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Drill Expert? Answer questions, earn points and help others
