Question about Canon PowerShot A95 Digital Camera
CCD problem and then lens problem
My canon A95 would display purple images after 2 years of its use.
I got it corrected wiht free replacement as it was a CCD issue and after 1.5 years I am not able to take any pictures and the canon service says its issue with lense and it would cost 70% of the amount I paid back in 2004.
Is it canon`s marketing strategy?
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Sep 26, 2009
  • 10,594 Answers
If the symptoms are similar as it was ccd imager problem then contact again with Canon for again free replacement of ccd imager chip in camera.
Can you post an image here that shows purple problem?
And if its lens problem as said by Canon then new camera would be better option instead of spending on its repair.
Thanks.
Posted on Sep 20, 2009
4 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: powershot A95 ccd problem
This sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on Dec 14, 2007
t00nz
  • 4738 Answers
SOURCE: The pictures are purple on my Canon PowerShot A95.
test
welcomejee
  • 10594 Answers
SOURCE: Canon A95
Yes, ccd imager is about to defective completely like one day no image at all.
Canon offers free of cost ccd imager replacement for A95
Click Canon CCD Imager Advisory for details.
Thanks.
Posted on Dec 15, 2009
Testimonial: "Thank you for your quick response. I will take the camera into Canon to have them repair this. Thanks for your help in this matter."
Poor resolution with horizontal lines
This is known problem of ccd imager chip failure in Canon A95 camera, ccd imager chip will be replaced to get clear picture. It was coincidence that problem occurred at same time when you did some settings but it is not setting problem.
Canon offers free of cost ccd imager replacement.
Jul 05, 2010 | Canon PowerShot A95 Digital Camera
No picture display on the LCD screen
If camera shows previously stored images in memory card in playback mode correctly but does not show live view in camera mode to take fresh pictures then its problem of ccd imager chip failure that will be replaced to solve the issue.
Canon offers free of cost ccd imager chip replacement for Canon A95 and few other models.
Thanks.
May 21, 2010 | Canon PowerShot A95 Digital Camera
Canon A95. Image on screen flashes and is discoloured. Photo same
It sounds bad ccd image chip in your Canon A95 camera and ccd imager chip will be replaced to get correct live view in camera mode.
Canon offers free of cost repair for said problem, click Canon CCD Imager Advisory for details.
Thanks.
Dec 26, 2009 | Canon PowerShot A95 Digital Camera
Picture pink tinted and with streaks
It is known problem of ccd imager chip failure in canon A95 camera. CCD imager chip will be replaced to fix this issue.
Canon offers free of cost repair of ccd imager problem in A95.
Thanks.
Dec 19, 2009 | Canon PowerShot A95 Digital Camera
Pictures turning out dark, LCD not adjusting
CCD sensor problems usually present themselves as either a blank image, purple cast, or lines through the image. Incorrect exposures are usually a result of the lens shutter failing to open and close correctly. Typically, the lens is not servicable and they need to be replaced.
Apr 13, 2009 | Canon PowerShot A95 Digital Camera
View screen has purple lines across whole screen cant take a pic.
It is bad ccd issue in Canon A95 camera and ccd imager needs to be replaced.
Canon will repair A95 free of cost as per announced scheme.
Click Canon CCD Advisory for details.
Good luck.
Dec 21, 2008 | Canon PowerShot A95 Digital Camera
A95 LCD
Its problem of bad CCD Imager Sensor in your Canon A95 camera and this part will be replaced..
Canon has announced Free of Cost repair scheme for same fault in A95 models..
Click Canon CCD Advisory to see details for free of cost repair..
Nov 07, 2008 | Canon PowerShot A95 Digital Camera
LCD`
Canon a95 when switched on lcd screen gives psychadelic display in purple, black and white - like a sci-fi sunset on some lonely planet.
You Canon A95 has problem of bad ccd imager sensor and this part will be replaced.
Canon has announced free of cost repair scheme for A95 model for same problem. Click Canon CCD Advisory for details.
By the way, symptoms details in your question is really beautiful.
Good luck.
Nov 03, 2008 | Cameras
Canon PowerShot A95 Digital Camera Logo
136 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
