Question about Gateway MT6840 Notebook
I cant get my s-video output to work on my tv.
    Guru:
  • 830 Answers
Be sure you tell the computer you are using dual screens: See instructions below:
http://www.oceansystems.com/dtective/dual_monitor_setup.pdf
Posted on Sep 20, 2009
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    I have no TV output!
    This will only work with a dvd player, PS3, XBOX 360, and other gaming consoles
    You need:
    - 3 AV Splitters (2 Female 1 Male sides cord)
    - 1 Double sided Video and Audio Cables (Red, white, yellow cables)
    Connect your consoles Video and Audio cables to the female sides of the splitters, next attach the Video and audio cables you bought to the splitters as well.
    Now plug in the video/audio cables you bought into your TV.
    If you did this everything properly this should work.
    Sorry if this didnt help you
    Mar 25, 2010 | Pinnacle Dazzle Video Creator Platinum...
    Was playing my PS3 on an HD Tv but cant get it to work on a non hd tV
    go to
    settings>display settings>video output settings
    and then you change it to
    AV MULTI/SCART and it should work :-)
    Nov 28, 2009 | Sony Playstation 3 (PS3) Console
    I CAN RECORD FROM MY TV BUT I CANT GET MY ARCHOS 5 TO SHOW ON THE TV ,WHEN I PLUG MY ARCHOS INTO THE DVR STATION THE OPTION TO SET IT UP FOR TV DOES NOT COME UP . I WOULD BE VERY GREAT FULL FOR ANY HELP,...
    You should swtch your TV to the video mode on to the video output chosen for the device. Check the video connecion type by following the output cables from the DVR station or charging dock to to TV. it could be video 1, 2, 3 HDMI, Color stream HD1 , Color stream HD 2, by scrolling down on the video mode list you should get the picture on on of them with correct video mode. or like i was saying follow the output cable from dvr station to Tv to see which video mode it was connected.
    Jul 30, 2009 | Archos 5 MP3 Player
    Video Out
    i cant get no video from the dock all i can get is audio.... how do i get video
    Jul 05, 2009 | Starlite Next Play Clock Radio with iPod...
    Cant hook dvd/vcr to my cable box the manual says I need a extern
    The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
    Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
    Sony BDP-S350 - no video..only audio on all outputs
    This is button config for master reset without picture:
    Home Left button x 3 Down button x 7 ok (centre button) ok Down button x 6 ok Left button x 1 ok ok wait a couple of seconds for settings to complete, when you switch back on you should have a picture and be back at language set up screen.
    Hope this helps.
    May 30, 2009 | Sony BDP-S350 Blu-Ray Player
    Cant get hdmi for ps3 to work on my jvc hd 52g887
    Had same problem with Panasonic PT60LC14 tv when connecting by HDMI cord to my PS3 and a blue ray disc was playing. First, read your tv manual to see what video inputs it supports . Then read the PS3 online manual (section on "video output settings").
    For me I found out that my tv only supported 1080i (along with 480i/p, 780p) and the ps3 manual says blue ray outputs 1080p, so my blue ray discs will not play on my tv according to the PS3 manual. PS3 manual says to restart the ps3 (power off, then power on and HOLD for 5 seconds) - then the standard video output settings should be reset. Hopefully the ps3 menu will pop up at least. I haven't tried this yet but if it doesn't work, i'll may try to reset PS3 video out settings manually first using another tv that works with it ..
    Nov 07, 2008 | Sony Playstation 3 (PS3) Console
    No video signal
    Try turning the console off, then holding down the on button until you hear a series of beeps, each beep representing the system switching video modes. (try testing another output source to make sure your tv is working correctly) if your tv accepts other video signals then you should find the correct one from your ps3 with this method. you may have to get it to work on AV or S-Video to make the appropriate changes to the HDMI and set the proper resolution for your television first.
    Hope this helps.
    Mar 31, 2008 | Sony Playstation 3 (PS3) Console
    Video output issues
    this is probably a problem of the relays - yes, there are small relays inside to switch the video in/output.
    In this case i think the contacts are the problem. you cant open the relays, so they have to be replaced...
    better solution: use a better videostandard such as component or hdmi - do not use the receiver to switch the videosignals, use only for sound...
    mfg
    Feb 01, 2008 | Onkyo TX-DS595 Receiver
    Gateway MT6840 Notebook Logo
    59 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
