Question about D-Link Express EtherNetwork DI-604 Router
Non responsive my internet went down it is now up but won't go through my router how do i reset to get this router working
  • ProudBadMan Dec 14, 2007
    you were right, i needed to reastablish the PPPOE settings now its up and going thanks a bunch!!
    Scholar:
  • 112 Answers
Power off then power on both the internet service providers modem and your router, if the DSL does not link up through the modem to your router. You will need to reestabilish the PPPOE internet connection to your service provider, this can be done on the router or the PC. BPCS
Posted on Dec 14, 2007
TL-WR740N wireless router not working
I don't have the same router, but my router requires the reset button to be pressed and held for 20 seconds. Try that. Also, I have found the manual on-line. Try the link below:
https://www.manualslib.com/manual/534658/Tp-Link-Tl-Wr740n.html
Sep 30, 2017 | TP-LINK TL-WR740N Router
Printer wont connect to network and now won't print via USB
Dear, Model no not mentioned, If its not printing through net work or USB it might be formatter faulty,,replace it..
Jan 31, 2012 | HP Office Equipment & Supplies
Belkin54g router will not work with cable modem....but it works fine with the dsl modem ....all lights are on it just won,t go through the router. do i need a different router ?
You need to reset the router settings to work with a cable modem. If you don't have the original instructions that came with the router the easiest way to do it would be to hold the reset button down on the back of the router for 30 seconds (use a paperclip or some other pointed object). After that it will just start working by itself but it will not have any wireless security set up. To do that you log in to the router via your web browser. Open Internet Explorer (or whatever you use for internet browsing), type in the address 192.168.1.1. The username and password for that modem I believe is username: admin password: (blank). It should be printed on the bottom of the router as well. Then just follow the set up wizard.
Aug 21, 2011 | Computers & Internet
Was working ok then internet down and red light on router constant - have done the turn off turn on routine and reset router to no avail. have also plugged indirectly to computer - green light then comes...
Try rebooting both the modem and the router. It could be that the modem didn't pick up it's ip number when the internet went down. Then try pluggint you computer directly into the modem first to make sure it is setup and working properly. Then plug in the router (to the modem) and the PC plugged in directly to the router and check.
Once you have it connecting at that point then check the wireless settings on both the router and the pc. Then enable the wireless on the pc, unplug the LAN and switch to wireless network on the pc and see if it won't work.
If it works plugged in on the LAN but then not on the wireless then either your configuration isn't correct (ie wrong gateway ip number...gateway should be the same ip number as the router...ie 192.168.***.***) or perhaps the wireless part of the router died. It is possible for the wireless to die and the LAN (hard wired connection) to still work.
Aug 08, 2011 | Belkin N Wireless Router wireless router
My Belkin F5D8236-4 v3 Router won't turn on. We had a storm last night and the power went out but the router won't turn on. I have tried to plug it into different outlets to see if that would work...
Try resetting the router. There should be a little hole somewhere on it with a button inside that you can press with a paperclip. Try holding that button down while you unplug then plug the router in while holding it (if possible). If that doesn't work, I'd suspect the storm might've damaged the router somehow. Was it plugged into a surge protector, and/or have you noticed any other issues with anything else that was turned on at the time?
Jun 16, 2011 | Belkin F5D8236-4 Router
I have no wireless internet. It went out all of the sudden last night. This is an urgent matter as I need it for work. Resetting router does not work, cable modem IS in working order, orange light...
Just to clarify when you say your computer does connect with an Ethernet chord you mean you are able to connect to the Internet? If so, you should be able to reach the management console and reconfigure the wifi by following these steps
Else when you say you reset the router did you try to reset it to the factory settings by holding down the reset button for 30 secs as shown here?
Jun 08, 2010 | Linksys Wireless-G WRT54G Router
Loses internet connection I unplug or turn off the router then I will get the internet service for a little while it then shuts down. I contacted the cable service they sent a signal to the router box...
There could be a problem with this router's firmware that is why you are experiencing intermittent connection with it... Try hard resetting it and try reconfiguring it back again
Mar 15, 2010 | Linksys WCG200 Wireless Router
LinkSys WAP54G non-responsive...
upgrade the firmware and reconfigure it, still if it doesn't works then the router i faulty
Jan 23, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Our internet went down for several hours (it was an area-wide problem with our server). Once the internet came back up, my motorola 850G router will not work. I have reset the router, but the modem light...
(It worked for me for WR850G, when I had a similar issue. However, don't know how your connection is setup.)
1. Switch-off the ISP modem that connects to the router
2. Switch off the wireless router
3. Now switch on the ISP modem
4. Switch on the wireless router
Regards,
Warija
Dec 22, 2008 | Arris Wireless G Broadband Router (wr850g)
D-Link Express EtherNetwork DI-604 Router Logo
78 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
