Question about Kenmore 774 sq. in. Cooking Area Gas Grill 15337
Have kenmore quantum series model 415162320; need new burners; can not find on-line anywhere!
What is the capacity of the Kenmore 70 series model#11022722101
In the Kenmore line of washers and dyers, the 70 Series is a mid-priced family appliance that handles an average family's laundry needs. All appliances in the 70 series are freestanding and do not have stackable units. Available with both English and Spanish instructions, this mid-line series of appliances is suitable for almost any household needs. Kenmore Series 70 Specifications eHow
Jun 08, 2015 | Kenmore Washing Machines
Need schemedic for quantum 7to1 burner series about 3yrs old
Explore the links under Quantum to find your drive.
http://www.seagate.com/support/by-product/internal/
Feb 11, 2015 | Quantum Computers & Internet
Kenmore quantum series gas grill: where do I put the match to light it?
Using the wire match holder that came with the grill. Place the match in the holder, light the match and place it next to one of the burners. Turn the burner ON just enough for the gas to rise and the match will light the burner. Quickly remove the match and continue lighting the remaining burners you want to use.
Hope this helped you and thanks for choosing FixYa.
Aug 23, 2011 | Kenmore Grilling
I have a kenmore quantum series propane grill which i cleaned and now i cant get it to light and i smell the propane what should i check?
Donna, are you saying the ignitors are not working or that the burners just won't light? Not even by match lighting them? All this makes a difference in providing a solution for you.
Please advise. Thanks
Jul 29, 2011 | Kenmore 16228 Grill
I need to know were i find the igniter on my kenmore 70 series and replace it
Thi igniter is on the burner assy located in the bottom of the dryer. This manual will tell you how to open your dryer. It does not tell you how to change the igniter but it does show how to access the burner. The igniter change out is a matter of unmounting the existing one and unplugging the connector then install the new one. The burner access is through the toe panel discussed in the manual link above.
If you need more assistance would provide your model number please so we both can refer to the correct data.
Thanks for using FixYa,
Kelly
May 07, 2010 | Kenmore 73952 Gas Dryer
Greetings -- My 3 year old Sears Kenmore gas dryer 600 Series model 776226 will not heat. All else works. No ignition from the burner area. Can you help me identify the problemed parts? I have the unit...
by the burners gas line which is the small line you will see a tube with a wire going to it. That is the spark ignitor which has gone bad and needs a replacement
Mar 13, 2010 | Dryers
I need an intake for a poulin push mower with a
"Model-Type-Code" numbers on a Quantum Series are usually located on the sheet metal right above the muffler. If not there, remove the plastic cover from the blower housing and check on the blower housing near the spark plug wire.
Hope this helps
Oct 02, 2009 | Poulan "Poulan" Push Mower
Burners light and go out on kenmore quantum
sounds like gas is not flowing enough to support all burners- if its propaine,then it has a Regulator that connects to tank. That Regulator is bad and needs to be replaced. Burners clogged or rusted is not a good thing also
Sep 29, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
2 big burners do not work
You either have bad burner control switches, or loose connection where the element plugs in to socket coming from control. This is common. You must check in where the elements plug in for loose, sloppy fit.
Jul 09, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Kenmore elite16690 gas grill - main burner replacement
Call 1-800-4MYHOME and request a brochure for that model. Then you can call the Parts line at the same number and order the parts you need.
The actual grill model number is 141-16690
May 03, 2008 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore 774 sq. in. Cooking Area Gas Grill 15337 Logo
438 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
