Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Washer is taking ages to finish, been on for about 4 and a half hours now, why is this happening?
  • 4,345 Answers
Typically, this is a water flow issue, what happens is the inlet filters plug....
Posted on Sep 20, 2009
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
Acer t180 restore
A restore- from start to finish- should take 1 1/2 to 2 hours as a general rule of thumb. However, you should be seeing some activity in that time frame. If it is sitting on the same screen for even a half hour, restart the process.
Just as a question, what are you trying to fix that you think you should wipe out the whole thing and start over? Maybe we can help.
Feb 15, 2009 | Acer Aspire™ T180 PC Desktop
My lg front load washer is blinking LE my lg front-load washer sometimes blinks LE and doesn't finish the cycle
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
Feb 07, 2009 | LG WM-2277HW Front Load Washer
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
Nov 09, 2008 | Whirlpool GHW9400 Front Load Washer
Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Apr 05, 2007 | Whirlpool AWG320 Front Load Washer / Dryer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
47 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
