Question about Pioneer AVIC-X1R CD Player
I have a pioneer avicx1r and when i try to eject a disc it keeps on coming up with mechanism error
The problem is the disc. It is most likely warped. I had the same issue and I actually removed the unit from the dash still connected, tapped the top and pushed the eject button and out came the disc. I played a little longer and reinserted the disc and it showed the error again, tapped it and ejected it then tried another disc and no problem at all. I tried several and they all worked and every so often tried the original one and it showed error each time. It seems as though the fact it was warped it was catching the unit or a sensor was seeing it as a problem and not allowing it to eject. Hope this helps
Posted on Sep 23, 2009
Testimonial: "thanks not tried your solution yet. but thanks very much for the advice."
  • 26 Answers
You have the solution written on the display. Take to the experts to fix it.
Posted on Sep 20, 2009
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
My pioneer AVH-p6500 shows error 02. I found out in the manual that it is from a scratched disc(so it would not play it). Problem is, I could not eject the disc it keeps turning the system off. Please...
Unfortunately the internal safety circuits are going to fight you here. The unit has detected a mechanical problem during the attempt to eject and shuts down to prevent further damage. You will need to dis-assemble the unit to remove the disc. It is possible that the lens has a dirt film on it that would prevent it from reading the disc, thus the 02 error code. This is not the easiest mechanism to work on. I would suggest that you seek a service shop for this repair.
Dan
Mar 20, 2008 | Audio Players & Recorders
Reading error/Mechanism error
Did you try reseting your unit?
Jan 24, 2008 | Pioneer AVIC-N2 Car DVD Player
E-9101 and EJECT
E-9101 error is for Mechanical time out, it means your player can not read the disc within the given time period.
You may have to clean your player, there may be dust, dirt or other particle into insertion slot.
djajay@inbox.com
May 14, 2010 | Pioneer CDJ-800 Turntable
Eject mechanism failure on cdj 400 ''E 9101''
did you find the motor and belt for ejection mechanism? try to replace that belt.
Apr 06, 2010 | Pioneer CDJ-200 CD Player
Cd keeps ejecting on pioneer 1500 error code 10
The manual says a code 10 is Electrical or mechanical. The say the solution is to turn the ignition on and off, or switch to a different source, then back to cd player.
Dec 10, 2009 | Pioneer DEH-1500 CD Player
Mechanism error
If your unit is still making noise like it is trying to eject, then give it a little help by using a tweezer to pull the disc out after you pressed eject. Then clean the eject's mechanism rollers by using a couple of Q-tips and alcohol. Stick the slightly wet Q-tip into the center of the disc player slot until you reach the rollers after that slide it against the rollers from side to side, when you do that the sliding switches will trigger the eject mechanism and the rollers will start to roll. After afew times change the Q-tip and repeat. Allow 10-15 minutes for it to dry out completly. It should work after that. But if your unit is making clicking sounds or no sound at all right now and it display mechanical error message, then you have deep mechanical problems. There are services on Ebay for about $100, contact Rick for service. He own SAME DAY AUDIO SERVICES, he is very reliable. You can call me too:801-414-4566. Good luck.
Dec 31, 2008 | Pioneer AVIC-N2 Car DVD Player
Disc wont eject
Hi jamie,
It seems you have opened the top cover of your unit. Now take a dry cotton bud clean the roller which you can find right in front. Please do not use any liquid to clean the same.
Please cast your vote for me if this solve your problem.
ramesh22
May 17, 2008 | Pioneer AVIC-N1 Car DVD Player
MECHANICAL DISC ERROR
There should be an emergency eject button, look in your instructions that came with it to locate it. Also check you book for the suitable DVD's for your machine. Or go to the panasonic web site
Feb 02, 2008 | Panasonic CQ-VD6503U Car DVD Player
Pioneer CDJ-800MKII
Any error codes??? you must provide some more info... is the screen blank? When you are trying to insert a cd do you hear any noise from the mechanism?
Aug 01, 2007 | Pioneer CDJ-1000MKII CD Player
Pioneer AVIC-X1R CD Player Logo
477 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
