I have a new!CD Soundmachine AZ302 and I cannot get the player to operate although it is switched on. I have the3 direction sheet with me. Many thanks. Marcia
  • 10,594 Answers
Plug AZ302 in AC wall socket, select source either AM-FM or CD by switch at back.
If CD is selected, press lift to open button on top to open CD door, put an audio or MP3 CD inside and close that door and press Play button to play that CD.
If source switch set on AM/ FM, need to tune radio frequency by button at top that is marked as -TUNING+
Volume control is just opposite of tuning button on top panel of player.
Let me know if you need to know any thing else.
Thanks.
Posted on Sep 20, 2009
CD/MP3 soundmachine brand new. Need more instructions.
try Google make model and manual with luck you will find some.
Jun 01, 2015 | Audio Players & Recorders
I haven't registered the product yet. It seems to be poor for the money paid. I'm hoping to get some answers on how to work it successfully.
sad but you got what you paid for no doubt . read your manual again but not registering it will not help as they go by the purchase date not registration date .
Jun 01, 2015 | Philips AZ302 CD-MP3 Soundmachine
Do I continue to keep this web page open for expected answer, or do I await answer by email??
If you made a question, presume about a Philips AZ302 CD-MP3 Soundmachine, you should be notified by Fixya if you have an answer.
If you don't get an answer, maybe your queston was too confused or maybe so one of those who read it could give you a good anser, so, try to reformulate it, make it clear and short.
Many people simply won't even read those PAGE LONG questons
I recently bought a NR1501 receiver and a CD5004 CD player at the same time. I don't use the tuner as I have a separate DAB radio. I use the Aux2 source for the radio input and the CD source for the CD...
How did you isolate it to the CD player?
Of course you know that this fault lies in the realm of the Twilight Zone as no 'intelligence' or commands are exchanged between the units via their RCA cables.
http://www.retrevo.com/support/Marantz-NR1501-Receivers-manual/id/23506ag717/t/2/
I'd try to eliminate the posibility that erroneous remote control commands are getting into the receiver from somewhere, either your own remotes or some other I/R source. Block the I/R sensor on the receiver and see if it switches spontaneously. You may haved a rogue I/R source in the room.
Do not allow direct sunlight, an inverter fluorescent light or other strong source of light to shine onto the player's infrared receptor window. Otherwise, the operation of the remote controller may be disabled.
• Bear in mind that operating the remote controller may cause other devices operated by infrared rays to be operated by mistake.
• The remote controller cannot be operated if the space between the controller and the player's infrared receptor window is obstructed.
• Do not place any objects on top of the remote controller.
Doing so may cause one or more buttons to be held down which will cause the batteries to run down.
Jan 20, 2011 | Marantz NR1501
2002 Lincoln LS electrical systems down- won't start
Removed CD player for jammed CD. Reinstalled but car ignition and most electrical sytems won't operate although fuses appear OK. Don't know if it is related to the anti-theft system.When ignition is turned on, both tach and speedometer needles peg out and return to zero but no type of ignition
Apr 05, 2009 | 2002 Lincoln LS
Cd player and hot (high temperature) CD's
As with all electronics... anything can happen (even unexplained). There are two things to think abou tin this expensive experience.
  1. 1.CD's are made of plastic and metal... excessive temperature can cause them to warp, but not as bad as the old vinyl.
  2. Mosy electronics have an acceptable operating temperature. Although the unit may work outside these limits, it is not recommended. ex:My Sony DVD R/W has a range of about 40-95 F. Being in Houston I am sure the upper limit is reached OUTSIDE the car. Inside you are probably pushing 120+.
It may not be convenient but if you have to leave discs in the car, try putting them in a case in the trunk, out of direct sunlight. And let things cool down inside the car before trying the CD player.
I have not seen this before but like I said, anything is possible.
MM85
Jul 21, 2008 | Car Audio & Video
Jvc kd g521 car cd player
Have you checked the cables? It appears that you have connected the wire for ignition directly to the power in and the direct +12v to the ignition cable. When turning ignition off, the memory is then emptied.
Jul 06, 2008 | JVC AM FM CD DET FACE CAR STEREO
Clarion stereo does not operate or turn on although it lights up orange even when ignition is off
HOOK THE UNIT DIRECTLY UP TO THE BATTERY IF THE SAME CONDITION EXIST THE UNIT IS BAD.
Jun 29, 2008 | Clarion DB245 CD Player
Aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Mar 18, 2008 | Audio Players & Recorders
21 people viewed this question
 Grubhead
Grubhead
