Question about Saeco Spidem Villa
Water and steam?
When I am running water through the nozzle, instead of steady hot water I get half water and half steam and lots of splatter. Can I turn down the temp on the boiler somehow?
  • 143 Answers
No. probably a scale problem or a blockage. run another de-scale and open the steam nozzle during.
Posted on Sep 20, 2009
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
When I turn on the steam valve, nor hot water nor steam comes out (not one drop), it doesn't make it to the nozzle and instead it goes directly to the drip tray. Coffees dispense works...
Hi, sounds like either you have a blocked or fauly solenoid, or micro switch or the water inlet side of the boiler is bocked. This is easy to fix. You need to be able to get to the inlet on the boiler, undo the water line and drill it out using a 3mm drill bit. Dazza
Sep 15, 2011 | Gaggia Titanium Espresso Machine
Window shows "Expel Air" message.
Fill the water tank.
- Turn the program selector to "On with
light" and place containers below the
hot water dispenser and the steam
nozzle.
- Press the hot water button, turn the
steam selector counterclockwise
and let water run out until it streams
steadily.
- Press the hot water button again.
Turn the steam selector to "o" to shut
off the water.
ENJOY YOUR COFFEE
Jan 15, 2011 | Miele Coffee System
Ventilate!....shows in window and machine will not ventilate when knob is opened. it has regularly been de-scaled but we do live in a hard-water area.
Generally you can clear the ventilate error by pressing the button for Hot Water and then opening the steam knob. You should hear the pump run and water should start to flow from the steam wand. If it doesn't, try removing the frother nozzle so just the chrome pipe is showing.
To remove the frother nozzle you slide the outer sleeve off, and then grip the nozzle with one hand while twisting the cap to loosen it. Then it should slide off the metal steam pipe. Or you can check that the tip of the nozzle isn't clogged.
If you have the frother removed and the steam pipe is definitely open and not clogged and you still hear the pump running but no water is coming out, the next step is to prime the pump.
If you still have the squeeze bulb pump that came with the machine, you can use that - or if you don't have it, a turkey baster will work. You want to take the water tank off and set it aside, then pump water into the valve in the center where the tank had been sitting. You choose "Hot Water" and open the steam valve so the pump starts and then pump water into that valve with the Turkey Baster. You should hear the pump catch and start to move the water - when this happens immediately close the steam valve so the pump stops - then replace the water tank (filled with water please) and open the steam valve again and let water run out of the steam wand for several seconds.
That should clear the ventilate message.
Oct 21, 2010 | Gaggia Titanium Espresso Machine
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Ventilate shows, nothing works
There is an air lock in the hydraulic line of the machine, thats why it is calling for ventilate, if hot water valve is open and it is still calling for ventilate, then it is possible that the valve is blocked, it might be at top of the wand or at the tap rod assembly.
Jul 28, 2009 | Saeco Royal Professional Espresso Machine
Water coming out of steam nozzle not coffee output when making coffee
Sounds to me there might be a blockage on the brew unit, and since the pressure is so high it is going through the bypass. Clean the screen and tubes on the brew unit.
May 12, 2009 | Gaggia Syncrony Compact Coffee...
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
Ventilate
I fixed my ventilate problem! After 2 days of utter frustration and pushing many buttons, I read another guest comment about resetting to factory settings. Push the up button under the small coffee icon. It should say factory setting with the asterick next to it. Push OK. Then push "yes" for factory settings. Then my machine started working again! Hallelujah! It erased my personal coffee cup setting, but who cares.
Big thanks to the person who posted their solution on Dec. 2007.
Jun 11, 2007 | Gaggia Titanium Espresso Machine
Saeco Spidem Villa Logo
161 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
