Kenmore 24 in. 15932 Built-in Dishwasher
Problem for Kenmore 24 in. 15932 Built-in Dishwasher
Top rack won't clean
By kimmagee on Sep 20, 2009
top rack won't clean
Solution #1
posted on Sep 20, 2009
Somewhat Helpful)
rylee_smith
Rank: Guru  Kenmore Dishwashers  Expert
Rating: 87%, 971 votes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Solution #2
Not Rated)
muebe
Rank: Guru  Dishwashers  Expert
Rating: 90%, 264 votes
Make sure the top rack spray arm moves freely. Check that there is no debris stop water flow inside the spray arm. When you load dishes make sure no dishes stop the spray arm movement. Check the pressure hole where the arm inlet slides into. Make sure if there is another pressure hole that the check valve flap is not stuck open. The water pump in your system might have low pressure due to a plugged filter screen. If your dishwasher does not have a self-cleaning screen you may need to clean it. If it is clear then the pump might need replacement.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 15932 Built-in
Questions and Unsolved Problems for Kenmore 24 in. 15932 Built-in
Do you recommend Kenmore 24 in. 15932 Built-in Dishwasher?
Answer
Answer
Our kenmore Ultra Quiet has blinking pots and pans and cancel lights flashing and won't cycle.... (More)
Answer
the kenmore model 66517364300 is washing for three hours and I hit cancel and drain it. The light... (More)
Answer
My friend's Kenmore Ultrawash Dishwasher wasn't cleaning very well, and didn't drain completely, so... (More)
Answer
My QuietGuard3 is making a lot of noise. It seems like maybe there is something stuck in the chopper... (More)
Answer
water has not drained, green light is flashing and dishwasher won't start
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore 24 in. 15932 Built-in...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1581
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
