Question about Refrigerators
Need to unhook water line to my frigidaire - Refrigerators
    Sergeant:
    Champion:
  • 323 Answers
Make sure the water supply valve to the unit is shut off, if you take the toekick off the front of the unit the shutoff may be located there, otherwise pull out the unit slowly and check behind the unit
Posted on Oct 24, 2009
What size water filter should be used for this ice maker Frigidaire IM115?
Thank you for your post, friend!
Based off the information you have provided you need to know what size water filter needs to be used for a IM115 inside of a Frigidaire refrigerator. Typically, the IM115 needs an in line water filter and that would be attached on the line. If you need additional information on that part I would recommend contacting the manufacturer for assistance. Hopefully this is helpful. -Matt
Feb 12, 2015 | Frigidaire Refrigerators
Water wil not despense
Could be a few things. Either the water filter is not in correctly. The water line could be frozen in the door or in the cold water reservoir that is in the refrigerator section behind the bottom drawers. You can tell if it is frozen in the door if it is a SxS by unhooking the water line before it goes into the bottom of the freezer door. Just unhook it at the pressure fitting and then try to get water. If it is frozen in the door then water will come out of the unhooked line when you try to get water. Also could be a bad water valve.
Oct 19, 2014 | Whirlpool Refrigerators
We just purchased the Frigidaire FGHC2378LP and hooked up the water line and it worked, no problem. Then we unhooked the water supply from the water shut off valve for 3 days and hooked it back up and now...
Sounds like its frozen, is why you arent getting water unfortunately until you fix temp problem or unplug it to thaw it, its probably not going to work.
Sean
Mar 27, 2011 | Frigidaire FGHC2378L Side by Side...
We have on older top load Frigidaire washer. It has been unhooked and stored outside for a month, worked fine inside, but we got a new one. I want to sell it and was told to test it out by plugging it in,...
i would say this needs plumed into the water as sometimes there is a switch on the water line to detact the water,so by pouring water into the machine is no good as its dosent know its there.adrian,,,,
Jun 30, 2010 | Washing Machines
Not making ice
make sure the little wire handle is down on (over) the top of the ice bucket
Mar 29, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Water will drain out
I had the same problem-you have to open up the bottom front panel and unhook the filter. (has two clips that you need to unhook before you remove it) (If you are a woman-find a guy to do this-I cursed on those clips for two days before I was able to get them back on!) Make sure to put a bowl or a towel underneath as all the sitting/stinky water in the filter that is stuck there will come out. I found a sock and pennies!
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
Water leaking
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezerr.
Dec 27, 2008 | Frigidaire FRS26R4A Side by Side...
Filtered water quit working on my Frididaire side by side
although you had waterto the bottom of door when disconnected, did you try to dispense water while unhooked andsee it flow??? because just unhooking it will allow the resivoir of stord water to flow out by gravity, giving false sense of water working., if indeed it did work the you have a frozen water lin within the freezer door itself, ait tricky to defrost. aside form unplugging unit and allow to thaw out, or pulling line form liner not going to be easy to thaw the line. if you indded still hear the "hum" after disconnectng water under door, then it soundsas if you have a bad water inlet valve located behind refrig where the water atteachges to the refric, no repairingthe valve it needs replacing
Nov 20, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26ZSH no water at dispenser or ice maker
  1. I would remove both solenoids (one at a time-not to mix them up) pay attention and mark all parts- try cleaning or replacing them. Most are fairly common supply items. Paying attention to wiring and proper installation is important during re assemble. JOHN-LA
Aug 31, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
