Question about Kenmore Elite HE4 Electric Dryer
It will make a beep sound with HF light blinks when it gets on Rinse and spin and stops
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error HF on Kenmore washer means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:-
  • Make sure that both valves at the water source(s) are turned on all the way.
  • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • Check inlet valve operation.
If there is water in the unit:-
  • Check Drain pump operation
  • Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
However, it is also caused by a clogged drain filter.
Step One: Unplug Washer
Step Two: Remove front Panel from Washer
Step Three: Locate Filter Assembly(and be ready to soak up water with a towel)
Step Four: Remove Filter. It’s Gross. Check for some coins, socks, toothpicks,etc.
Step Five: Clean Filter
Step Six: Replace Clean Filter
Step Seven: Reinstall the Front Panel. Run load of clothes.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Sep 20, 2009
Haier HLP21n blinking light error code.. Rinse and Spin lights blink...what does it mean?
This washer is a sanyo on the inside. When panasonic bought out sanyo and all its daughter brands, they started making parts not available for repairs. The service manual is here---> https://panasonic.encompass.com/shop/research_new/HAI/sm/HLP21N.pdf
This is also known as a sears proflex among other names.... haier-hlp21n-blinking-light-error-code-eqln1e0r5dvuapuxoxy4lmrd-1-0.jpg
Dec 09, 2014 | Haier HLP21N Washer
3 lights and loud beeping
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Dec 12, 2013 | Fisher and Paykel Washing Machines
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Kenmore he4t code hf
hf error stands for hot water not being detected, make sure both hot and cold water are open and not reversed. if unit overfilled and flooded garage, the is if with you pressure switch or pressure hose. remove to lid of machine and you will find pressure switch and hose to the right side, inspect hose for any pin holes, if ok, order pressure switch
Apr 03, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Model Gw709AU
Feb 20, 2013 | Fisher and Paykel Washing Machines
MODEL WASHER # FTF214OFS2 BLINKING AND BEEPING LIGHTS WONT STOP
Hello Jennifer Brookman - Unfortunately from what you are describing it sounds like the washer is either experiencing a communication error from the control board or wiring failure. Since you have already tried the basic troubleshooting by flipping the household circuit breaker off, do you notice if the door is securely latching? If it is not, then the issue can also lie with a faulty door latch assembly. I suggest contacting a professional for a proper diagnosis and to move forward accurately.
Feb 10, 2013 | Frigidaire FTF2140F Front Load Washer
The washer will go through the wash cycle, but will not rinse or spin. The machine stops and beeps with the red light at the end blinks while it beeps until i stop it. Please help!!
HI - A RED LIGHT ON ITS OWN MEANS THERE IS A COMM PROBLEM BETWEEN THE DISPLAY & CONTROL MODULES. THE FAULTY UNIT WOULD BE THE DISPLAY, THIS IS A TOUGH ONE BECAUSE THIS DOES NOT ALWAYS WORK, OFTEN THE ACTUAL PROBLEM IS THE CONTROL MODULE ITSELF.
I WOULD BE INCLINED TO REPLACE THE CONTROL MODULE INSTEAD..
CHEERS
Jun 25, 2011 | Fisher and Paykel GWL11 Top Load Washer
F&P washer lights on and beeps
Clogged pump stopped up drain. If the washer does not think all water was pumped out in 8 minutes then it shuts down. Slow drain is my first inclination.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 31, 2009 | Fisher Paykel EcoSmart GWL15
The machine stops at wash cycle every minute or so
Firstly, the model 708 is way more than 9 years old. More like 18 - 19 years old. There is 2 types of errors on a smartdrive. One is signalled by a single beep every second & the top row of lights will change. The 2nd is a rippling musical sound (like when you turn the power on at the wall) and some lights will be blinking. You need to tell us what sound it is and which lights are blinking or which of the top row lights are on (exactly, count from the right to left and which number is on & which is off) There is no such thing as a reset to do. Once I know the fault I can advise you what to do about it.
Mar 10, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Kenmore Elite HE4 Electric Dryer Logo
148 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
