Question about Canon MultiPASS MP730 All-In-One InkJet Printer
How do i set it back to factory setting's,i messed with the( enlarge/reduce ) and my print is to small to read
How do i enlarge print size on my email
try this - when you have your email open - by your X tab where you close the window, there should be a tools tab (place your cursor over tab & don't move it & a small box will appear to tell you what the tab is used for) .
left click on tools tab, a box will open, on my page the 3rd one down is the zoom.
place your cursor over the zoom & a 2nd box will appear.
move your cursor over to that box & over the percentage that you want to increase your zoom, then left click.
this will increase the size of your picture & print until you go through the process again to reduce it.
I have mine set @ 100% until I get something with small print, then I enlarge it for a time.
you can leave it on what ever setting that you want.
Jan 12, 2015 | HP Computers & Internet
The print is too small to read so is there a way to enlarge the print without loosing the text that runs off the page?
Set the printer properties to default and also see if the paper setting is A4 or which is default inserted for printing.. you will get results... Good Luck.
Jan 07, 2011 | HP Deskjet F340 All-In-One InkJet Printer
When I print emails the font is too small. How do I enlarge it?
go to the propities printer, when you clikc print go to settings, find font settings and enlarge there is an option the option says enlarge font and then go to priview print, if you see any problem again , in priview settings you can change the margens, click on margen and change the page size and try to print
Aug 11, 2010 | Dell Inkjet 720 Printer
My MFC-3240c won't copy. Has been fine up to now
Hello may I suggest doing a simple reset of your machine. If you have not tried this please do so.
Simply unplug your printer power wire from the printer and wait about a minute. Now plug it back in and your problem may be resolved.
Next, if this does not make sure you do not have any print jobs backed up in your computers printer cue.
This can be done by looking in the bottom right corner of your computer monitor. look for a printer icon. If there is on there click on it and cancel all print jobs.
Also, check for paper jam, make sure paper is not causing problem.
_________________________________________-
finally, here are the steps to enlarge and reduce. just in case there is a step you are missing.
Press options: UP or Down arrow.
Enlarging or reducing the image copied
You can select the following enlargement or reduction ratios.
Custom(25-400%) allows you to enter a ratio from 25% to 400%.
1 Press (Copy) to illuminate it in green.
2 Load your document.
3 Use the dial pad to enter the number of copies you want
(up to 99).
4 Press Options and ▲ or ▼ to
5 Press ▲ or ▼ to select the enlargement or reduction ratio you
want.
Press Menu/Set.
—OR—
You can select Custom(25-400%) and press Menu/Set.
Use the dial pad to enter an enlargement or reduction ratio from
25% to 400%.
Press Menu/Set.
(For example, press 5 3 to enter 53%.)
6 Press Black Start or Color Start.
Mar 28, 2010 | Brother MFC-3240C All-In-One InkJet...
How do I enlarge a page so I can read it? When printing something from the internet, how do I enlarge the print? I have printed a pattern and cannot read it.
There's no option to enlarge the font or text of what you are printing from the Internet. What you need to do is to copy the page that you would like to print and then paste it in a Word document.
From the Word document, there's an option for you to change the font size and color.
Have a great day!
Dec 05, 2009 | HP Photosmart C4580 All-in-One InkJet...
Print too small
it's just the paper setting, try to setting the paper correctly on the printer properties
Jun 08, 2009 | HP Photosmart C7250 All-In-One Thermal...
Need help setting printer to print regular size
On your printer, there might be a button saying Enlarge/Reduce. Keep hitting it until you get 100%. Good Luck.
Nov 15, 2008 | Cannon Canon i960 Photo Printer
Problem printing full screen
sounds like your printers settings have accidentally been set to print a smaller area. When you print, look into the area that says page settings or properties before you print, you may find the settings altered. If the settings are set to print full page, then post back as we will need to explore other issues. Cheers lilacgerry
Sep 15, 2008 | Lexmark X6170 All-In-One InkJet Printer
Need to enlarge printer font too small to read
Dear Sir/Madam,
At the left side of ur printer there is adjustment for the font settings or u go the printer settings (Go the Control panel ->Printer and faxes -> right click of properties -> select printing preferences -> adjust paper and font size
Thanks
Good luck
"Don't forget to rate the solution"
Jun 09, 2008 | Office Equipment & Supplies
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
46 people viewed this question
old marine
old marine
