Question about House Brand Aqua-Pure AP102T Whole House Water Filter System
Nsf 100 aqua pure, nsf 100 ran out of salt...doesn't seem to be working now
I have a jandy pda and have no idea what the message that its displaying means. This is our first pool and the owners manual has not helped! It says aqua pure 100% salt 4500 ppm, check aqua pure high salt...
it is showing your status aqua pure is set at 100% salt is at 4500 parts per million which is too high to operate should be between 2700 and 3400 to work properly you need to drain some water out and add fresh to dilute the salt general fault is because salt level is too high it is showing your filter pump and extra aux is on go to the equipment on on main screen it will give you a list of all your equipment any questions send me more info
Sep 20, 2013 | Jandy Aqualink Pda Ps6 Wireless Handheld...
Fault comms eror what does this mean
if aqua pure salt system check sensor and salt level then cell
Jul 28, 2013 | Jandy Stealth 1.5 HP UR Pool Pump SHPM1.5...
The system keeps showing "no flow" and the hand held asks to check aquapure.
inside aqua pure there is a card hooked to the salt sensor cable there is a button to hold down until a green light shows then see if you get flow if not need new sensor
Jun 20, 2013 | Jandy AQUALINK RS TELELINK KIT
How do I fix a PDA with general fault message? What can can suh a reading?
general fault is the aqua pure either not enough salt or too much salt check salinty or the sensor or cell needs cleaning or replacing
Nov 05, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
Jandy PDA-PS4 lost link to salt system?? There is no more
go to system setup find aqua pure up setting from 0 to something and it will apear
May 27, 2012 | Jandy Aqualink Pda Ps4 Wireless Handheld...
We have a GE Model GXSF27E01 water softener. It
Try looking on the computer board for a battery back up. If it does have one, unplug that and then plug it back in and see if that will reset your control.
Jul 18, 2009 | House Brand Aqua-Pure AP102T Whole House...
House Brand Aqua-Pure AP102T Whole House Water Filter System Logo
74 people viewed this question
Top House Brand Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a House Brand Garden Expert? Answer questions, earn points and help others
