Question about Craftsman 4 Cycle Blower/Vac
Pull starter handle is locked in it's orginal position,pulling on the handle does nothing
  • 124 Answers
Unless the starter rope jumped track and is causing the problem, it sounds like the engine is locked up.
Posted on Sep 20, 2009
Testimonial: "I had the same feeling,I just did not want to come to that same conclusion,THANKS FOR THE SUPPORT."
Poulan gas hand saw is locked reset handle will
Are you referring to the chain brake handle or the handle you pull to start the saw? To reset the chain brake handle, pull it back towards the rear of the saw, this may take some force. If the starter grip or handle will not pull out then your saw may be seized or something is wrong with the starter its self.
Oct 19, 2014 | Garden
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
I serviced the carburetor and i cannot get the pull the start cord
Make sure you have assembled the starter correctly, assemble loosley pull the starter handle until you hear the pulley fully engage into the starter pawls on the flywheel and the cover sits down easily, now fully tighten the screws.
Feb 10, 2013 | Solo 450 Mist Blower
My door wont close on my 2003 moutaineer
YOU PROBABLY HAVE THE LOCK ON LOCK POSITION. OPEN THE DOOR, PULL THE OUTSIDE HANDLE OF THE DOOR UP AND WITH SCREW DRIVER PULL THE LOCK IN THE MIDDLE OF THE DOOR TILL UNLOCK POSITION, THEN CLOSE THE DOOR.
Dec 26, 2012 | 2003 Mercury Mountaineer
I have been trying to turn on my chain saw. Ive pulled the handle back by the trigger gave a few pull on the rope. then i pushed the button in on the side also the push the button back in by the trigger...
The chainbrake should be activated when starting the chain saw. Activate the chain brakeby pushing the front hand guard forwards.b>Cold engine Start position, 1: Set the start/stop switch in the choke position by pulling thered control outward - upward.Decompression valve: Press the valve to reduce the pressure in the cylinder and makestarting easier. Once the machine has started the valve will automaticallyreturn to its original setting.Air purge: Press the air purge diaphragm repeatedly until fuel fills thediaphragm (at least 6 times). The diaphragm need not be completely filled.Grip the front handle with yourleft hand. Hold the chain saw on the ground by placing your right foot throughthe rear handle.Pull the starter handle, 4: Pull the starter handle with your right hand and pull out thestarter cord slowly until you feel a resistance (as the starter pawls engage)then pull firmly and rapidly until the engine fires.Push down the red choke control: As soon as the engine fires which can be heard through a"puff" sound, push down on the red choke control.Pull the starter handle (6): Keep on pulling the cord powerfully until the engine starts.
Nov 18, 2010 | Husqvarna 450 e-series 18" Chain Saw
Loola handle won't lock into position
I had this problem and was discussing it with another loola mum. If you pull the handle and push down on the top of the bit it locks into at the same time, it locks first time - I've had months of frustration due to this and it was solved so easily!
Aug 06, 2009 | Baby Gear
Can't open the back door of my LR3
If its a problem that the rear door handle is stuck in the upper position, then you need to use a screwdriver to pull the handle down , then use wd40 and spray up into the handle mechanism. Its common that handles stick, due to road dirt wafting up there as you drive along.
If this is not the case , and its due to the lock mechanism itself, then you will have to get into the rear compartment and remove the door trim pad, then pull the plastic protection away and get access to the lock mechanism. Check that a lock rod has not broken or fallen off, try to lift the unlock rod and see if the door opens, in which case you can adjust the rod and that should do the trick, it maybe that you need a new mechanism, they can fail.
Hope this helps
Feb 14, 2009 | 2005 Land Rover LR3
Lock out bmw520i 1990
There is a procedure to open the doors in a lock out. You must pull up on the driver's door handle then insert the key and turn it counterclockwise while at the same time pulling the key as if you were trying to pull it out. You will be met with a lot of resistance but the lock will open provided your actuator is not froze. This is a tricky procedure and will no doubt take several practices to be able to pull it off. Good luck!
Jun 21, 2008 | 2007 BMW 525xi Sedan
'87 auto
There is this pull handle.
It might be locked into place, so you lift it up and pull it out i believe
then you change your steering wheel position then you push the pull handle back in
and push it down to lock it in.
Jun 09, 2008 | 1987 Honda Accord
Craftsman 4 Cycle Blower/Vac Logo
142 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
