Dish Network Vip722 does not recognize Seagate Showcase 1TB Drive
I have the exact problem. This is my second Seagate Showcase Drive. The first one, worked fine for a few months, and then I started getting the message on my DVR that said ''There is no multimedia device connected to the USB port''.
I reset the receiver many times, unplugged the Seagate drive and re-connected it to both the front and rear USB port with no success. I also swapped cables with a known working USB cable.
I called tech support for both Dish network and Seagate. I was back and forth with each because neither could diagnose the problem.
I eventually got Seagate to RMA the drive and I got a replacement. The new drive has worked fine for a few months and just in the last couple weeks, intermittantly, the DVR will not recognize the drive.
I also have a 500GB external drive from another manufacturer that works fine, and my thumb drive works fine.
I hope someone finds a solution for this, (other than running over the seagate drive with my car).
Same problem here, 722 not recognizing Seagate Showcase, been going on for months now. Per Seagate advice, I replaced Dish Network Receiver, no help, finally pressed Seagate after all their "troubleshooting" (which was no help at all) & they said to return Showcase & they'd send out another. Well they didn't send me back a Showcase, but (2) 1TB external computer hard drives. Now my 722 recognizes this computer drive is there, but: 1) you can't delete anything from it once it's on there, you hit "delete" & it doesn't delete, it's still there. Contacted Seagate about this & they said to delete programs you'd have to "wipe" the entire thing by unhooking it from your DVR, plugging it in to your computer, then "wiping" (erasing) the entire contents of the drive. WHAT???? I bought the drive to store some things I'd like to keep until I have time to watch them, store other things that I'd like to keep permanently. I don't want to "wipe" the contents of the entire drive. Good grief, that isn't how this was meant to work, you are supposed to be able to add/delete any program you wish, WITHOUT having to "wipe" the entire contents of the drive by hooking it to your computer. 2) you can't "resume" something after you've stopped watching it say, halfway thru, you have to manually find where you were by skipping or fast-forwarding, 3) if you pause program you're watching, it won't restart by hitting "play", you have to hit "skip fwd" & then it will skip forward & resume playing, 4) if you hit "stop" while watching a program, it just "freeze frames" & then won't take you back to your menu (like it should), it just freezes, & to "unfreeze" it you have to again hit "skip fwd", doesn't respond to anything else 5) sometimes it recognizes the programs you have recorded, other times it does not, thus your programs you've recorded you know are there, & the DVR is recognizing the unit itself, but unless you pull out the USB, wait, then plug back in the USB, it doesn't show you your recordings listing at all. I have no contacted Seagate & have now (I feel) exhausted all of my options. I am DONE, stick me with a fork. I asked Seagate why they didn't send me another Showcase, which is what they should have done, but they replied "we're not sending any more of those out right now". Hmmmm, sounds like I'm not the only one having this problem, huh? Why else would they not send me out a replacement of my original purchased product, but try to replace it with (2) computer drives instead, which is not what I purchased, I purchased a Seagate Showcase, because it is the ONLY drive recommended by Dish Network to be "the" drive exclusively meant to work w/Dish Network....ha ha. Somebody needs to go back to the drawing board here, Dish Network blames Seagate, Seagate blames Dish Network. I'm so done with all this that I don't even care any more who's problem it really is, or if the problem is a combination of both companies products perhaps, all I know is I'm finished. I am returning both of these computer drives, and am FINALLY supposed to be getting my money back. Hallelujah, Amen, I'm getting off of this roller coaster & won't be riding again anytime soon.
Posted on Dec 18, 2009
Check out the link below for more information. You may wish to RMA your current drive as well. My 1tb Showcase just took a dump in the same fashion. According to Seagate support, the problem has been fixed with a new firmware revision. Guess I'll know a few months after my replacement arrives... -)
http://www.satelliteguys.us/dish-network-forum/163103-potential-problems-certain-1tb-seagate-western-digital-external-hard-drives.html
Posted on Oct 09, 2009
I had the same problem. Just got off the phone with Seagate and they are sending me 2 each 1 TB external hard drives as a replacement for my Showcase. They said they have not had any problems reported with the 1 TB external hard drives they are sending me. They are basicly sending one as a replacement and the other as a "here's an extra free hard drive for your problems" or it could be that they have to because the replacement drives are less expensive. I paid the $21.64 for the advance return so that they send the new driver first with the pre paid shipping of the return drive. I am hoping there will be a way using my PC to transfer what I have recorded on the Showcase to the new drives.
I will post my results after I receive the new drives.
Posted on Nov 25, 2009
My Showcase also stopped working unexpectedly after about 8 months. The problem being the DVR was unable to recognize when the USB Showcase drive was plugged in. Even though it is still under warranty I didn't want to loose the 180+ movies I had recorded on it. So I purchased an Airbox 3.5" external HD enclosure and transferred the Seagate HD to it. As soon as I plugged the Airbox into the DVR, it immediately recognized it and I now have access to all my movies.
Posted on Jun 11, 2010
I recently bought a Seagate Backup Plus Portable Hard Drive with 1TB of storage. The first time I used it, I was able to drag and drop around 100 photos from my Mac without any problems, but the second...
Oh I have the exact same problem - its because its not formatted for a mac. You need to empty the device before formatting as it will wipe whatever is on it. If you format as FAT32 it can be used by both mac and PC.
Jan 12, 2015 | Seagate Backup Plus 1tb Portable Drive For...
I have a seagate goflex 1tb external drive. The drive is not recognized by the usb 3.0 adapter unless I only use the very short seagate cable that came with the goflex. I need the extra length but off the...
I have the exact same drive. If off-the-shelf cables are not working (which is odd) I would suggest buying a USB 3.0 extender. This will extend it about 3 feet. You can purchase them for <$5 online! Let me know if this helped out any.
Jul 08, 2011 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Is there anyway to get recorded shows back that were accidently deleted?
Hey there, Cheri Torres with DISH Network Customer Service here. There is unfortunately not any way to get recorded shows that have been accidentally deleted. What you can do for next time is connect an external hard drive to your receiver. The external hard drive will need to be a minimum size of 50gb and maximum size of 2tb for DVR receivers and minimum 50gb and maximum 1tb for non DVR receivers. This will save all recorded shows in case anything should happen to your DVR receiver. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com.
Jun 02, 2011 | DISH Network ViP722 DTV Receiver /...
I've had an external hard drive connected to my Dish DVR for the past year, precisely because earlier problems made me worry that if the receiver died, I'd lose the recorded programs I had saved. ...
Hi my nameis Mike Houston of DISH Network and I see the External Hard Drive wants toreformat the hard drive. The question I wanted to ask is are you taking thehard drive and connecting it to a computer, please e-mail me for further help. michael.houston@dishnetwork.com
May 10, 2011 | DISH Network ViP722 DTV Receiver /...
For the past couple of days, every show our DVR has recorded freezes a couple of minutes into playing it and the DVR reboots itself. This always occurs at the exact same time on that show. We don't have...
Hi, Mary with Dish Network Customer Service. Since the DVR is the only thing having the freezing issue, it sounds like it maybe a hard drive issue. I would recommend resetting the receiver. Unplug it from the power supply for 10 seconds and then let the receiver reboot itself. If you are still having this issue, I would recommend calling Dish Network and we will need to replace the receiver. Hard Drive issues do not resolve themselves and only get worse over time. Please let me know if I can be of further assistance.
Jan 13, 2011 | DISH Network ViP722 DTV Receiver /...
I am having a problem where my DVR will suddenly skip from the place I paused it to Live Tv without any warning. It has gotten perpetually worse as time as gone on and I am unsure of how to fix it.
Hello! Daniel Busa with Dish Network here. It sounds like your hard drive may be going out try unplugging it for about ten seconds. If you still have issues you can contact us on twitter or by phone 1800-333-3474.
Dec 04, 2010 | DISH Network ViP722 DTV Receiver /...
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Dish dvr does not recognize storage expander any more
I dont have a solution. Just to say that I have had the same problem, on about 3 occasions. (Out of the blue, it will suddenly workon a random day, when I unplug and replug the USB cable. But somee days I can unplug replug 20 times or more and the DVR will not recognize the Showcase). Talked to Dish network a few times. They seem to be aware of the problem, but they will only say that they are working on it. Two of their reps have told me that it is a problem with the DVR design, not the Seagate Hard Drive, and the "fix" is to just unplug / replug the USB cable until it works. Go figure.......
Apr 01, 2009 | Computers & Internet
Need Dish DVR ViP722 remote code.
If you are looking to have the Dish remote operate your TV, just do a random search for your tv. First, hold down the tv button on the dish remote until all the rest of the light up. Next press the tvpower button on the dish remote. Next, press the channel up button (this is the up arrow button) until the set turns off. When it does turn off, press the # key at the bottom right of the remote. The tv button will light and flash twice. That's it. Your done. Hope this helps.
Feb 20, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Open Questions:
Computers & Internet Logo
2,860 people viewed this question
Alun Cox
David Payne
David Payne
