Question about Acer Aspire 3623WXMi Notebook
Windows Media player keeps popping up.
I tried the suggested- Start menu-misconfig-startup- uncheck WMP files. There are no WMP files running. I do have one file that has nothing in the name but the box is checked. Could this be the file? We have tried so many things to get rid of it but it keeps coming back. We uninstalled it and it was gone for about 4 days then it came back.
  • 66 Answers
A program on your computer is using windows media to open.You can try running task manager to see which one it might be,or use system restore and go back to when it worked normally.
Posted on Sep 20, 2009
    Novelist:
  • 148 Answers
The file which doesn't has any name, is a spyware virus..
If it is marked please unmark it as it may cause several damage to ur system
If ur Windows Media Player is troublin u, click start,
Select Default Programs
Now Select the Windows Player as MP3 Universal Player..
After u do so, it wil take some time
After it is done, restart ur system
I guess it works..
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I am currently using nero as my media player but want to go back to using windows media player
Just click over a mp3 file with the right button of your mouse and select open with on the menu.
And then click to open on Windows Media Player.
Sep 24, 2009 | Microsoft Windows Media Player
Doesn't show up when i plug it in to my laptop
To download music or photos on to your Philips GoGear, you need to use a computer that has Windows Media Player and Device Manager already installed. Once these are installed, the steps to sync your Philips GoGear Jukebox using Windows Media Player are fairly easy to follow. Follow these steps to sync your Philips GoGear.
Connect your Philips GoGear to the computer with the USB cable. The USB connector on the GoGear is on the top, and will be on the front or back of your computer. You will see a USB connection icon as soon as the GoGear is connected to the computer.
1.Start Windows Media Player from the Start Menu or from the desktop. To transfer files to your GoGear from your computer, click Copy to CD or Device (with WMP 9) or the Sync tab (with WMP 10). 2.Find the Items to Copy pane. In the drop-down list, click the category or playlist that you want to copy to your GoGear. Make sure that items that you do not want to copy are unchecked. 3.Locate the Items on Device pane. In the drop-down list, click GoGear. When you have selected the items that you want to sync, click the Copy (with WMP 9) or Start Sync (with WMP 10) button.
Apr 25, 2009 | Audio Players & Recorders
Wmp 11 on vista
right click on your cd rom drive. Click on properties, then, autoplay>Select Music cd from dropdown menu. then select "take no action" for disabling WMP popup , if you have another cd player software, choose it to make that popup when you insert cd.
Sorry to say, That wonf fix your WMP but the problem. And sorry, there is not enough info to help you on WMP fixing.
Thanks
and yes, please dont forget to Rate, if it works.
Apr 10, 2009 | Microsoft Windows Media Player
Application rtl100.bpl
Hello!!
Insert ur XP cd and boot it thro the cd and enter the repair console and try FIXBOOT command .. or try the other method .. run msconfig .. and disable the error in startup menu .. thanks for using fixya!!
Feb 23, 2009 | Dell Microsoft Windows XP Home Edition
How do I make WMP my default player instead of Real Player??
Control Panel -> Add/Remove Programs. Then, on the left, click Set Program
Access and Defaults.
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Windows Media Player Keeps Popping Up.
ok, you need to type msconfig in the in the search bar in the start menu, when the window pos up select the startup tab and uncheck the boxes that says WMP in the name, and click apply and exit, reboot the machine so the registry is updated, now you will ahve the pc booting without WPM starting up at all!!!!!
any probz and post back'
kind regards and don't forget to rate us please
Nov 27, 2008 | Acer Aspire 3623WXMi Notebook
Media player not playing mp3.
this may be due to the loss f any codec due to which wmp cant play it,but still real player has the codec
Oct 11, 2008 | Microsoft Windows Vista Ultimate Edition
Windows media player not working
Very the file you are trying to play is still there , if it is then create a new play list by allowing WMP to scan your system for playable media. If this fails or the above aint the latter then i'd suggest you uninstall WMP and reinstall it. WMP is in the control panel / add or remove components / Windows Components. You can also log in to microsoft web site and download the latese WMP and install it .
Jul 09, 2008 | Microsoft Windows XP Home Edition
Windows media player can't play .wmv files
  • Firstly a UPS is an abbreviation for Uninterrupted Power Supply - meaning emergency backup power in the event of a mains power failure. This is not a type of PC.
  • Secondly - Windows media player does not support every type of movie format, as Microsoft Update it from time to time, some formats will still not be supported, these are known as codecs.
  • Thirdly, codecs to support your particular format can usually be downloaded and added to Windows Media Player, however i can not think of any reason .wmv files are not supported by Windows Media Player.
You could try re-downloading the latest version of Windows Media Player from one of the links provided below.
WMP 11 will support the latest codecs, but if for some reason you find yourself needing the older version, use WMP 10.
You will most likely have to remove your current version of WMP, and you can do this by using Windows Add/Remove programs.
  1. Click on the Start menu button ( bottom left corner of your screen. )
  2. Click on Control Panel.
  3. Click on Add or Remove Programs.
  4. Click on Windows Media Player in the list.
  5. Click Remove ( right hand side of the listing )
Microsoft WMP 11 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/11/default.aspx
Microsoft WMP 10 is available by clicking on this link:
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
WMV 11 is available by clicking on this link:
http://filehippo.com/download_windows_media_player/
Feb 05, 2008 | Computers & Internet
Acer Aspire 3623WXMi Notebook Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
