Question about Amana Washing Machines
Amana washing machine model LWA65AW,about 10 y old, leaking from bottom when spinning cycle starts
  • 66 Answers
Probably loose hose.
Posted on Sep 20, 2009
Washer leaks when on spin cycle
drain is not working properly so that only spin is not starting
Jun 06, 2010 | Washing Machines
Very loud on high speed spin cycle Sounds like jet turbine Frigidaire Model FWSB67RGS0 almost 10 years old. Was given to me. Don't know if it has always been this loud.
Most likely the tub seal on the bottom is starting to leak water onto the bearing under the tub and now the bearing is starting to go bad.
Jan 01, 2010 | Washing Machines
HOW TO REPLACE A BELT ON AN AMANA LWA65AW wash machine
FIRST DISCONECT FROM POWER AND THEN REMOVE ALL SCREWS HOLDING MACHINE PANELS IN PLACE , LOCATE BELT TIGHTINER LOOSEN AND REMOVE OLD BELT , THEN FIT NEW BELT AND AJUST TENSION .
Nov 01, 2009 | Washing Machines
Washing machine will not agitate but it spins.
The brakes are shot,so the tub spins in agitate will also cause it to leak part number R0000014 run about $25.
Look straight up from the bottom pulley you will see the brake assy looks kinda like a clutch plate,look around the outer edge of that you'll see the Pads they have two 3/8 inch bolts in each one,to get the new ones in you'll have to use a screw driver to open the plate.
Sep 23, 2009 | Amana ALW480DA Top Load Washer
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Leaking at drum where drive shaft enters
hi thanks for the question .your problem is major save yourself a lot of aggravations purchase new a nice washer is called roper built by whirlpool but cheaper same quality thanks the appliance doc
Sep 28, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
AMANA WASHER WILL LEAKS WATER IN TUB AFTER SPIN CYCLE.
Cylon, sounds like you need to replace the water inlet valve. It's not seating and weeping water. For series 10 the part number would be 40097701. Not that hard of a job. Catriver..post back.
Feb 20, 2007 | Amana ALW880WH Top Load Washer
Washing Machines Logo
190 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
