Question about Freezers
Noticed frigidaire upright freezer wasn't cooling properly (all ice cream was melted). Noticed dried green puddle under freezer when we moved it out and some wetness(but the wetness was clear liquid, possibly water). Found solid ice along back bottom crevace inside of freezer. Currently defrosting and hoping that melting the ice will solve the problem as it appears that the ice may be blocking some sort of vent. Is this possible? Freezer sounded as though it had been running continually. Do you think that it could be a coolant leak? We did have a power outage recently do you think that the ice may have formed then or do you think that we have a bigger problem? Any suggestions?
  • 124 Answers
Make sure the condenser fan is working.
Posted on Sep 21, 2009
Frigidaire Freezer Model FFU17C3AW1 door not sealing properly?
Good Afternoon Vonaspern,
I understand that you are having trouble with the door sealing properly on your Frigidaire freezer, model# FFU17C3AW1. I see that you have already checked to make sure there is nothing blocking the door from closing as well as making sure there was nothing between the door gasket and the freezer body. Next, I would check to make sure that the gasket is not damaged or compromised in any way. If it is not damaged, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your freezer and determine what is causing your appliance to properly seal. Hope this is helpful.
-Best Regards-
WP
May 12, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have a Frigidaire upright freezer. It lives in our garage. It hasn't been moved in 4 or 5 years. I have never had a problem until yesterday, when the ice cream decided to melt. We took most...
HI Not sure if you have checked . BUT i would check to make sure the cooling fan is clear and not blocked. Dust and dirt and cat hair and dog hair can collect in and around the vents and and keep it from cooling properly. If it is the type of condenser that is on the back of unit then disregard.
Apr 04, 2014 | Frigidaire Freezers
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Freezer seems to be stuck in defrost mode
Sounds like the pat test fried the pcb. They use too high a voltage to test the appliance wiring and it doesn't do printed boards much good!
May 11, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Frigidaire upright LFFU1465 and it is on but not blowing cold air.
If the condenser is clean and the temperature rising, the freezer is short of gas
Apr 13, 2012 | Freezers
I have a Frigidaire ffu1466gw0 Upright Freezer. It is a frost free freezer and doesn't seem to be cooling properly. Some items seem to be solid enought, but ice cream is melted for the most part. I have...
if the compressor is running, the fan beside the compressor and the fan in the freezer should both be running, dirty coils can cause a problem. frost buildup on back of freezer wall is indicative of defrost problem.
Jul 26, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer bad smell
the defrost pan is located under the frig. if there is a cover at the bottom on the front remove it and the pan should slide out
Nov 17, 2008 | Frigidaire Freezer Refrigeration White...
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Apr 20, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
394 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
