Question about Cameras
Sony camera showing message: the tape is locked - check the tab
  • 1 more comment
  • guy_haegeman Sep 20, 2009
    The answer is NOT satisfying, as the tape tab is in the correct position (i.e. in record mode). The camera keeps on showing the message: "tape is locked - check the tab". Camera cannot be switched to stb position !!
    Guy Haegeman
    The Sony camera indicates: "tape is locked - check tab", but the tape tab is on position 'record'. So, it must be some other artifact! The camera canNOT be switched to 'standby' position.
    Thank you for this very useful information ! However, where do we find the little arm, about which you are talking and how does it look like ??
    President:
  • 2,185 Answers
Hi there, Guy,
1. Take the tape out of your sony camcorder.
2. From the tape cartridge, somewhere on the top corner, look for a little tab which is most likely to be open. If that is open, it wont let you record, thus the error.
3. Move or slide the tab to close the position.
4. Gently put the tape back inside your camcorder and try again.
Goodluck and hope this helps.
Posted on Sep 21, 2009
    President:
  • 1,653 Answers
This generally indicates that the tape you are using is write protected by a small tab on the tape. To unlock it simply slide it to the unlocked position. If this does not work then try another tape first and if this still does not work then take a look inside the tape compartment of the camera to ensure that the is no debris covering the small arm that jumps into the tab slot on the tape when it is inser5ted. It is fairly common for this to happen. Any debris should be carefully removed with a cotton bud that has been wetted with isopropyl alcohol - do not use surgical spirit as this contains oil and will leave an undesirable residue.
Posted on Sep 20, 2009
  • 10,594 Answers
Please check Record Tab at right corner at rear side of tape either it is Video-8 or MiniDV tape and set it to Rec position as currently it is on Save position and camera senses it and tells you " tape is locked"
Below image of tape will help you to locate record tab.
Thanks.
Sony camera showing message: the - af36ff2.jpg
  • Shahid Electronics
    Shahid Electronics Sep 21, 2009
    stb position !!
    Guy Haegeman
    There was no intimation of tab set on record position in first question so I started with basic but got assistance rejection. Now I get very rare chances to post further info due to website system.
    I will try to help you out if you can provide me model number of your Sony camcorder.
    Thanks.
Sony camcorder
The tape is locked by a pin on the cornerside, check the locking hole on tap.
Jul 18, 2008 | Sony DCRHC90 Digital Camcorder Extra Gear...
HVR-HD1000E, The tape is locked-check the tab
hello, i think the tape tab is jammed if you will need help to: Disassembly,Repair, Maintenance or adjustments and more you can download the factory service manual from the below link:
http://goo.gl/ubSnD
Good Luck
May 01, 2013 | Sony HVR-HD1000U Camcorder
When i try to start shooting a video,a message is displayed on the screen saying:the tape is locked-check the tab.
The message is telling you that the tape you are using has had the write protect tab removed. This is done to keep from taping over something you want to keep. Try onother tape.
If you know this is not the peoblem (like a new tape) you could hav a problem with the camera
Oct 19, 2010 | Sony DCR-HC23E DV Digital Camcorder
Tab locked
TRY USING RESET BUTTON ON CAMCORDER .IT WORK FOR ME.
Oct 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony dcr hc21
There is an unlock tab on top of the tape. Switch the tab to the opposite direction.
Jun 10, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
