Question about Emerson SpongeBob SquarePants 3D Sculpted DVD/CD Player
No sound but plays the dvd fine
This thing was just working the other day and I put a dvd in and it plays but no sound.......I have checked the volume on both the dvd player and the tv. I have switched cables and switched how I have it hooked up. I tried different movies. The tv works fine with sound with anything else plugged up! Help!!!!
  • burntsinamon Sep 06, 2008
    I have the exact same problem... No sound but, dvd plays just fine.... HELPPPPP, we bought this for my 6 yr old niece & she is upset she can't play her favorite Disney movies on her own dvd player
  • Anonymous Feb 05, 2009
    Same problem. It worked yesterday but today the picture is fine but no sound. The TV has sound and I've tried other cables but still no sound with a DVD
  • 61 Answers
I think this is due to wrong Audio settings.
Try to change audio setting as Stereo/Right or Left/5.1 from the Audio setup of the Menu
Posted on Mar 11, 2009
4 Suggested Answers
  • 518 Answers
SOURCE: DVD Freezing / skipping
It almost has to be the discs. Try them in a friends unit.
I had a similar problem with DVD's I burned and had printed labels and put the label on the discs. It caused the disc to be out of balance. I peeled them all off (what a job) and the discs play fine now. I'm now a "magic marker" person... :)
Geno
Posted on Feb 10, 2008
  • 5 Answers
SOURCE: RCA DVD player "No Disc"
Cleaning the eye CAN work, especially if every disc your trying is failing, and the discs work on another player. Some links from reputable sources:
http://www.techlore.com/article/10478/
http://www.ehow.com/how_2036277_fix-error-dvd.html
After all that fails, it's probably time to change the DVD drive inside the player. Sometimes this is easy, sometimes not. :) I haven't been inside a 6300 but from looking at pictures, it's probably got a fully removable unit.
Of course, if you have a valid warranty, then when you're left with no solutions that don't void the warranty, you have to decide whether to try to pass it off to the warranty holder for repairs.
Posted on Apr 03, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Posted on Mar 01, 2009
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
When my tv is playing regular cable the volume doesnt work but when i play a dvd in the dvd player volume comes out of the tv, whats wrong?
Good--sound when playing a DVD means either a setting is wrong and it can be in the set or a box if connected---it also means the audio output circuit is good.
Worst case is where sound is developed by the set's tuner there may be a problem but check all audio settings first---
Jun 12, 2012 | Hisense LHD3204US 32 in. LCD HDTV
Dvd player makes humming sound while playing disc's
Hello ray sanders ,
But still the dvd plays right ??
Mar 31, 2008 | Televison & Video
Very weak sound on television from dvd. player recently bought. It is a Silvercest KH 6524 player and some official dvd discs.. Even using maximum volume of my t.v. , a flatscreen Samsung and my...
Some brand name of the DVD player.Some brand name DVD player,u must used it own DVD player remote to turn on the volume higer or lower to get it up or lower on the movie DVD discs or any kind of DVD discs are playing.The tv dosen't control the output volume of the movie,if the function require the DVD player remote to do it.Check ur DVD player remote see if u have a volume control buttons + - used those buttons on the DVD remote control u will control the volume of the movie DVD disc it is playing on the DVD player.
Aug 09, 2011 | Televison & Video
When i insert a dvd into the disc drive and play it, the dvd plays but the sound that goes with it does not. i have tryed re-installing several times, no result. how can i make the sound work.
You have to check the sound settings on your PC. Don't know which O/S you have but with windows Xp, click on Start - Control panel - Sound and audio devices - Volume - Advanced. Check the CD player is included in the volume control, and not muted. If not in the volume control, click on properties and add it.
Feb 06, 2011 | Samsung Super-WriteMaster SE-S164L DVD?RW...
Have an acer aspire 5516 and cannot find any sound when playing a dvd
check your sound and audio devices. Or you can see icon tray on the right-bottom. See picture "speaker" on there? Double click it, and please be attention in that check in "Mute All". Don't get that check, if you wanna hear some sound after you are playing some DVD's in PowerDVD software.
Sep 18, 2009 | Acer Aspire 5610-4648 Notebook
No sound on DVD's
hi there, its a software problem, or the dvd driver software. try to check your os software. ty
Dec 24, 2007 | Computers & Internet
Dvd sound isn't working
In addition to the suggestion which I fully concur with, there is one small thing I would add. Kari you may not be aware that there is often an "internal setting" in the dvd player for its output volume. Sometimes the setting is inadvertently changed to a permanently "muted" or silent mode so that no audio can be heard. This internal setting is usually accessed by pressing the "Setup" button on your remote control and browsing through the main menus to the "Audio" or "Sound Setting" submenu. Once there you will see if the settings are correct in order to HEAR AUDIO (sound that is). Be sure to turn the "MUTE" to "off" and set the output volume to about 3/4 high setting. Then get out of setup mode and play your dvd. My point is this...on some "kareoke" feature units I have found many people mistake the front manual volume control for a DVD audio output level control when playing dvd's. This is not the case..the output volume settings are "internal" and accessible through the remote control only. Hope this helps Kari !- hattonhall
Sep 08, 2007 | RCA DRC8300N DVD Recorder/VCR
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
Losing treble at higher volume
There are two things. First check the sound settings of the DVD player. It might be putting out a lower quality sound on the CD side of things.
Secondly try to determine if the speaker tweeters are working. Connect the speakers if you can to another sound source. If the speakers are good and the settings fine. Then you have a fault in the amp unit.
May 26, 2017 | AAD C-600i Main / Stereo Speaker
Emerson SpongeBob SquarePants 3D Sculpted DVD/CD Player Logo
186 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
