Question about Bosch Evolution 500 B20CS50SNS
Ice maker not working bosch refridgerator
Water dispenses when dispenser button is pushed but no ice comes out when I put it on the ice setting, (shaved or cubed). When I put a glass against the dispenser pad I can hear the humming noise, but no ice comes out. I used to be able to hear the fridge making ice on it's own in the middle of the night but I haven't heard that noise in a few weeks.
Had the same problem. If there is ice in the bin make sure the ice bin is in all the way. there is a
drive gear in the back that has to be engaged. If the
bin is emty open the little door where you can see
if there is ice, on the left you will see the square
end of the ice maker unit. Slip your fingers under
the front face, palm of your hand facing up so you
can feel the bottom of the front of the unit. Over
to the left you will feel a button that you can not
see. Just push it in for a few seconds and the unit
should start. One other thing, make sure the limit
switch is pulled down, thats the plastic on the
wire which shuts the unit off if it is full. Good Luck.
Posted on Nov 01, 2009
    New Friend:
Have had issues with the icemaker for two years, since it was delivered and I am so sick of it! Have had more than 8 service calls, replaced the ice maker and same issues. Something is wrong with the fridge or the design!
Bosch needs to make this right!!! Already wrote to them!
Posted on Mar 24, 2014
  • GiGi
    GiGi May 17, 2014
    yes this refrigerator stinks, i had a repair person out at least 6 times, it seems the techs don't know know to put it together correctly, or a defect in design.
    New Friend:
I also had trouble - no power at all to ice/water dispenser. Repairman tried ALL five control panels, and no luck! Said not enough voltage is going through the wires. Thinks a new door, or Bosch defect! Never buying Bosch again - trouble with new dishwasher AND ventless dryer.
Posted on Aug 15, 2014
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
Ice maker works and dispenses but water does not work, replaced water valve but no luck
Try a really good defrost. I often find on higher settings the freezer will freeze the pipe.
Dec 27, 2013 | Jenn-Air JSD2697KEF Side by Side...
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Water dispenser is not working
Does it make ice? If it makes Ice, then you have water to unit. If No Ice and No Water, check water supply. Otherwise, you could have a bad water valve. Remove valve and the line coming off of valve to water reservoir try to dispense water and if valve is good you should have water coming from valve. (have a bucket or bowl handy to catch water).
Mar 28, 2010 | GE Refrigerators
Water dispenser works, ice maker makes ice but doe not dispense
Remove the ice bucket/container from inside the freezer compartment. Examine underneath at the front of the container to see if ice cubes are lodged between the metal blades. If cubes are caught in this area, they will prevent ice from dropping into the glass/cup.
Feb 22, 2010 | KitchenAid Superba Architect KSCS25INSS...
The water dispenser does not work properly. The light does not come off of the cubed ice button. To get water, I push the water button and without pushing the lever, water starts coming out. To stop it, I...
You have a bad main control board . The new pt # WR55X10656 . The dispensor board is not communicating with the control board . However , check this site to see if it can be replaced under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
Nov 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
In door ice maker not working
In some cases, living in an area with extreme humidity, the ice dispenser door can stick open ( a small flap in the chute that delivers ice into the glass). This can cause a problem. The grinder in the dispenser sounds like it is frozen. Try using a HEAT GUN (hair dryer) on a low setting to defrost the dispenser DO NOT TRY TO MELT THE PLASTIC! Or a quicker solution, Unplug the refrigerator and pour water thru the dispenser CAN BE A MESS try to catch in a bucket or pan. Remove the dispenser from the door clean and dry as necessary and reinstall.
Try using cube ice to see if this helps. The occasional cup of cubes will dislodge stuck ground ice in the dispenser.
ABOVE ALL BE CAREFULL THE GRINDER CAN CUT YOUR FINGERS OFF. ELECTRIC SHOCK IS A DANGER AS WELL.
Sep 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Bosch Evolution  500 B20CS50SNS Logo
12,279 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
