Question about Compaq Presario 5000 PC Desktop
When my computer boots, all i get is a blank screen
  • Fla-Hosting.net May 11, 2010
    I will assume that when you attempt to start the computer that the Monitor is on and the Yellow "Standby" light is illuminated and doesn't change to the Green "On" light. Do you hear any beeps from the computer case¿ Does it sound like the Computer would normally sound when you start it up¿
  • 66 Answers
What OS was on it?Try turning it on and holding the shift key down while it is starting up,if nothing happens.turn it off then try holding the ctrl key down.That should bring up safe mode options.
Posted on Sep 20, 2009
Will not boot up. blank screen
Can you see any light on your computer? Or hear your computer running? Have you tried turning of the power and turning it back on? Also check if the cables on the back of your monitor are still firmly connected. as well on the computer side.
Listen for the computer if it makes any kind of sounds when you turn it on.
Jan 08, 2015 | Computers & Internet
Blank screen after boot splash screen
Hi.
After you see the press Del and F12 message repeatedly tap the F8 key, see if that gets to the advanced boot menu, if it does select "Repair my Computer" from the list, and then follow the prompts. Have your Win 7 disk ready just in case you need it.
Let me know how you get on and good luck!!
Jan 02, 2013 | Computers & Internet
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
E640 REBOOT
Hi John,
I see you mentioned you update IE9 then you now get a blank screen...
If I may ask the blank screen showed up after the update or did it show up after restarting the computer?
If your getting a Blank screen when you boot into windows after the IE9 update, try rebooting then boot into Safemode.
Restart you computer then as soon as you see the Boot screen of you computer keep on Tapping f8 to get a list select safemode, then once it boots into safemode windows will load up in safemode on the issue and you can navigate arround to fix things that went wrong.
click on the Start Button on the lower left of the task bar then, click on Programs, select accessories then select system tools, look for system restore then select the option select a different restore point, on the window you may see a list of restore points hoping your system restore was turned on in the very beginning, once you have selected a restore point keep on clicking next then a warning will show just click next again then it will restart your computer.
System restore allows you to restore to a date where you had windows working fine without any problems so if you can get a restore point before updating IE9 then it is possible that you may be able to fix you windows back the way it was.
I hope that this will help,
michaelvincentc
Dec 22, 2011 | E-Machines W Computers & Internet
TV PC SCREEN MODE BLANK
It probably cannot display the PC resolution, try lower the PC Video reolution to the TV native resolution.
http://s807.photobucket.com/home/budm/allalbums
Jul 04, 2010 | Sanyo DP19648 19 in. LCD TV
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Computer won't boot
hi there,
in this case you mention that it check then system configuration and then goes blank,so therefor your windows XP installer is corrupted replace your windows installer.regards and have a nice day don't forget to rate me.
Apr 08, 2009 | Computers & Internet
Blank screen when booting up
Why are you trying too boot in SM ?
Feb 23, 2009 | Sony VAIO VGN-FS980 Notebook
Xp boots and hang up on blank screen
Insert the original Windows XP "System Restore" CD-ROM,
and tell your computer to "boot" from it.
Does it boot, and get to a screen that asks you "do you really want to ...", or does it stop at a "blank" screen?
If it "stops", you have a "hardware" problem.
If it "asks", then either:
* your disk-drive has failed, or is about to fail,
* your installed copy of Windows is messed-up, and it cannot complete the "boot" process.
Take your computer to a computer-store, for more trouble-shooting.
Aug 28, 2008 | Computers & Internet
Computer won't boot
Make sure your computer detects the hard drive and is set to boot from it.
Dec 06, 2007 | Western Digital (WD3200JS) 320 GB Hard...
Compaq Presario 5000 PC Desktop Logo
46 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
