Question about GE Refrigerators
Refrigerator GSM23YCPA BS every day appears ice in the bottom area of the frezzer and licks water to the kitchen floor (It has never been installed the ice maker) During 30 days the device was left full of food on in the house for vacations but the energy went off and I had to clean it all (with a lot of water), after this the door magnet (lock) is not working and ice is created in the bottom of the freezer lickyng the water in the kitchen floor everyday
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
catriver
  • 878 Answers
SOURCE: Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Posted on Apr 22, 2007
yalmer
  • 552 Answers
SOURCE: frigidaire refrigerator with ice maker leaks water
It sounds like your ice maker is leaking.
If you are able, try opening up the ice maker for a visual inspection.
just remember to unplug first.
Apparently there is a leak somewhere.
Sometimes ice makers will over flow if the float gets stuck or a connection has come loose.
If you cannot work on it yourself, then I suggest looking up a service technician on the Fixya website.
Posted on Apr 22, 2008
  • 72 Answers
SOURCE: Viking freezer leaking
you have a clogged drain, it is either clogged with ice or some kind of debris, thaw the freezer out and push a length of weed trimmer line down the drain. The drain is accessible by removing the back wall of the inside of the freezer. If there is no clog then the drain may be freezing up, if that is the case, take a piece of 14 gauge romex wire and loop it several times around the heating element at the bottom of the evaporator and push a few inches of it into the drain, this will get hot and transfer heat when it goes into a defrost cycle which is where the water is coming from in the first place
Posted on Jun 17, 2009
rablack66
  • 48 Answers
SOURCE: Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Posted on Nov 13, 2009
Testimonial: "Many thanks for your help. The drain was blocked with ice as you suggested. "
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Why is there a layer of ice on the floor of the bottom freezer of my refrigerator?
The water most likely is coming from a defrost drain blockage. Unplug and remove the rear panel inside the back wall of the freezer. See panel location #4 in the photo=> HERE
You will need to get that panel out of the way to see and clean out the defrost drain.
Click Here=>Leaking Refrigerators
I am here should have questions, Thanks John Tripp Appliance 911
Jul 23, 2014 | Maytag 22 cu. ft. Bottom Freezer...
I have a side by side kitchenaid and the frezzer works every two days I find the bottom or floor of the frezer has ice built up,if I dont remove it The ice melts and leaks out the front of the frezzer,I...
Remove the back panel and get to the drain trough. Using a hair dryer heat until it starts getting a lot of water. Dry with towel and repeat. After several minutes take some boiling water and pour in the drain trough and let set. Do this with ref off. After about 30 minutes the tube will be cleared again. Hope this helps. Rick
Apr 27, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice froming at the bottom of the refrigirator
Check that the drain is clear. If it is blocked water will back up and spill on the floor and can potentially freeze. Otherwise you may need service to install a drain heater.
Jun 13, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Kenmore water on floor
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Water keeps filling bottom of lower freezer in my refrigerator
sorry, about the timing, you have aclogged drain tube, your "self-defrosting" refrig isnt able to allow the derforst water to escape( tube if frozen) so it baks up into the frezzer area and eventually will drip into the frig. you will need to remove the back cover of freezer sect, and with a hair dryer remove all the ice from the drain trough area and clear the frozen drain tube area
Sep 23, 2008 | Refrigerators
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Brad Goodale
