Question about Jet 708598/JSG - 6DC - CS Closed Stand Only JSG - 6DC - CS Closed Stand Onlyfor 6 X 48 / 12sc Sander , Sanders - Accessories
Unit never get to full running speed before tripping breaker on Jet JSG-6DC, sander/grinder
  • 143 Answers
Earth lekage fault most likely. Return to service centre
Posted on Sep 20, 2009
Where Where can I find an owner's manual for a TriStar Sander Grinder model number BDS-96?
It looks like they might have dropped the line on the item that you are asking about but here is the link. Send them email: http://www.tristarindia.com/contactus.html
Jun 04, 2014 | Televison & Video
Fix sander
You likely have something bound up or a bad bearing. Take the belt off and turn things by hand to verify they work smoothly
Apr 16, 2014 | Jet 414551 J-4200A Industrial Disc Belt...
I have a Husqvarna extractor fans, the type with the motor on the roof. In seems to work fine on full power but not no the lower power settings. It also trips out when the light and extractor are on at...
The 'trip out' is where the unit draws more power than the breaker is rated for. Because it runs ok on full power (check they are running at full speed on this setting), the breaker is allowing enough power to reach the unit in this setting, so the breaker is fine. However when you switch on the light with the extractor it trips, at that point it is drawing too much power through the breaker at it trips to stop the device burning out. Check the connections to the unit are clean and dry and firmly made, if not power could leak away drawing more from the breaker. The next step is to measure how much power is being drawn by the unit in each mode, using an Ammeter in line with it. If you do not know how to do this (its dangerous if you get it wrong) ask an electrician to check the current draw in all modes.
Dec 19, 2013 | Garden
Oscillating drum sander runs a few minutes and stops
This usually occurs if the motor is overheating and the internal circuit breaker is tripping. After it cools down, it self resets. This can be caused by bad bearings or parts dragging the motor down, making it work hard enough to over heat and trip the breaker. If you are running it on an extension cord or circuit that isn't able to provide it with the amps it needs the motor will overheat and trip the breaker also.
Dec 02, 2012 | Delta 17-960 Oscillating Spindle Sander...
My heil heat pump has been tripping circuit breakers. It might run 8 hours to two days before it trips. I replaced the breaker. They put a hard start on the compressor. Now they say the next step is the...
Have you noticed what the outdoor temperature is when this unit is tripping the breaker? Does it seem to be at a higher outdoor temperature or at all outdoor temperatures day and night?
Did they check the run capacitor to see if it's good and the proper microfarads?
Did they check to see if the breaker trips when it's starting up or after it has been running awhile.
If it's tripping on start up then it's possible the next step is the compressor replacement.
If it's tripping after running awhile then it could be dirty indoor coil or filters,blower not running at full speed,low voltage, loose wire connection, points burnt on contactor and even a weak run capacitor.
Dec 30, 2009 | Heating & Cooling
My delta 31-250 sander dc drive motor will not run. The machine has only been used for 26 hours total. the dc motor quit during the sanding of a 12" board after the third pass.
Did the DC drive give you a fault code? It may have tripped on a current over load. Needs to be set to handle load.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 28, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Jet 708598/JSG - 6DC - CS Closed Stand Only JSG - 6DC - CS Closed Stand Onlyfor 6 X 48 / 12sc Sander , Sanders - Accessories Logo
104 people viewed this question
Top Jet Tools & Hardware - Others Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you a Jet Tool and Hardware - Other Expert? Answer questions, earn points and help others
