Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
My machine stops in midcycle, beeps displays f6
My machine stops in the middle of the rinse and drain cycle displays f 6 and beeps, does not fully drain. how do i fix this?
  • 15,935 Answers
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 – is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
What is Error Code "F6E1"
I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
Jan 14, 2012 | Whirlpool duet Washing Machines
My washer stops in the middle of the cycle and displays F-1 and after I have to set it on the rinse / drain cycle to complete. Today for the first time it also displayed 5d at the end of the cycle.
5d or Sd means too much detergent was used. Try the following
Run the unit through a RINSE/SPIN cycle.
Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
Jun 29, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Mar 18, 2009 | Kenmore 24032\24036 Top Load Washer
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
CHECK DRAIN HOSE coming from washer TO ENSURE WATER IS DRAINING PROPERLY down drain.
USUALLY YOU CAN RAISE DRAIN HOSE A LITTE AND RESET WASHER TO RINSE & SPIN F6 is caused by water not draining Fast Enough
Dec 12, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Robert Rankin
