Question about Denon DRA-397
Remote lock on
I can't use my remote
  • Anonymous Dec 15, 2007
    Buttons on the panel or unit itself work but the remote control , nothing works. When you hit a button on the remote it just says remote lock ON , on the unit.
This worked for me, but I'm sure tired of constantly searching for ways to fix the problems I encounter with my Denon DRA-397. When it works, it's great, but I don't have a degree in electrical engineering. Why can't they produce a user friendly trouble shooting guide?
Posted on Jul 06, 2008
Power off.  Turn on power while pressing  "speaker b" and "mode". This unlocks the panel.   If still not working, reset the chip by power off, then press "speaker a" and "speaker b" while turning power on.  The display should flash to indicate the reset.
Posted on Jul 07, 2008
Turn off receiver using the on/off button. Hold speaker A and B and Turn back on
Driver side door locking with remote but will not unlock, if i unlock it with key then remote will unlock all other door, if all doors are locked remote will not unlock the car. Once i manually unlock...
it is not the actuators, try a different remote, you may have an issue with the car security system/body computer not functioning on the unlock driver door command, one press of remote is unlock driver door and 2 presses is unlock the other doors.
Sep 01, 2012 | 2003 Mitsubishi Galant
Tip
How to Program Acura Remote Transmitter
Acura Remote Alarm / Central locking
Model: CL Year: 2001-2003
Model: TL Year: 1998-2006
Model: MDX Year: 2001-2006
Model: RDX Year: 2007-2009
Model: RL Year: 1996-2004
Model: RSX Year: 2002-2007
Model: TSX Year:2004-2008
System Operation
  • Pressing remote transmitter LOCK button once activates alarm and central locking.
  • Pressing remote transmitter UNLOCK button once deactivates alarm (if fitted) and unlocks driver's door only.
  • Pressing remote transmitter UNLOCK button once also activates driving position memory. Driver's seat and mirrors move into memory position specified on remote transmitter when driver's door opened.
  • Pressing remote transmitter UNLOCK button twice within 5 seconds unlocks all doors.
  • Pressing remote transmitter trunk release button for 2 seconds activates trunk release.
  • Pressing remote transmitter PANIC button for more than 1 second activates panic alarm.
  • Pressing any of the remote transmitter buttons deactivates panic alarm.
  • If vehicle unlocked and doors not opened within 30 seconds, locks are reactivated.
Synchronization.
when
  • Remote transmitter battery replaced.
How
  • Press remote transmitter LOCK button or UNLOCK button 5-6 times.
  • System should now lock and unlock vehicle to indicate synchronization procedure complete.
  • Check operation of remote transmitter
Programming
How
  • Obtain all remote transmitters.
  • Switch ignition ON.
Proceed as follows:
NOTE:Point remote transmitter at central locking signal control module (located behind glove box).
  • Within 4 seconds: Press LOCK button or UNLOCK button of first remote transmitter.
  • Within 4 seconds: Switch ignition OFF.
  • Within 4 seconds: Switch ignition ON.
Repeat procedure above twice.
  • System should now lock and unlock vehicle to indicate programming mode activated.
Within 10 seconds:
  • Press LOCK button or UNLOCK button of first remote transmitter, allowing doors to lock and unlock once.
  • Press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Switch ignition OFF.
  • Remove key
  • Check operation of all programmed remote transmitters.
Immobilizer
System Operation
  • System arms 5 seconds after switching ignition OFF. Immobilizer warning lamp flashes during this time
  • Immobilizer warning lamp illuminates for 2-3 seconds.
  • If immobilizer warning lamp illuminates for 2-3 seconds then flashes rapidly:
  • Key code not recognized.
  • Remove key and try again.
Programming
When
  • System malfunction.
  • Key added or replaced.
How
Immobilizer can only be programmed using diagnostic equipment.
Model: MDX Year: 2007-2009
Model: TL Year: 2007-2008
System Operation
  • Pressing key LOCK button once locks the vehicle.
  • Pressing key LOCK button twice within 5 seconds activates the alarm.
  • Pressing key UNLOCK button once unlocks the driver's door only and deactivates alarm.
  • Pressing key UNLOCK button within 5 seconds unlocks all doors and tailgate.
  • Pressing key UNLOCK button within 5 seconds and holding will open windows and sunroof
NOTE: Models with "Technology Package": Alarm central locking functions can be altered using digital multifunction display in instrument panel.
  • Pressing key PANIC button for more than 2 second activates panic alarm.
  • Pressing any of the key buttons or turning ignition ON deactivates panic alarm.
  • System will automatically lock all doors when vehicle is driven above 15 mph (if function selected).
  • If vehicle is unlocked and doors or tailgate not opened within 30, 60, or 90 seconds (depending on programming), locks and alarm system are automatically reactivated.
  • Pressing tailgate release button once will open, close or reverse direction of tailgate.
Programming
When
  • Key remote transmitter added or replaced.
How
  • Obtain all keys fitted with remote transmitters.
  • Ensure doors, trunk / tailgate and hood are closed and unlocked.
NOTE: A maximum of 5 remote transmitters can be programmed.
Proceed as follows:
Repeat procedure above twice. Locks should cycle when button in pushed.
  • Within 4 seconds of each other press LOCK button or UNLOCK button of each remaining remote transmitter to be programmed, allowing doors to lock and unlock once as each remote transmitter is programmed.
  • Remove key.
  • Wait 10 seconds.
Immobilizer
System Operation
  • System arms when vehicle is locked using the remote transmitter.
  • If key code is not recognized:
  • Engine starts, then shuts off.
  • Immobilizer warning lamp flashes once, then blinks until ignition is switched OFF.
  • With ignition switched OFF, immobilizer warning lamp will flash 10 times to indicate the system has reset.
Programming
When
How
Model: RL Year: 2005-2009
Programming
When
  • Remote Transmitter added or Replaced.
  • System Malfunction.
How
Remote Transmitters can only be programmed using diagnostic equipment.
Automotive and Commercial Locksmith Acura Remote Transmitter Programming...
on Mar 26, 2015 | Televison & Video
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
If i purchase 2 locks with 2 remotes, will the remotes work interchangeablely with the locks? I don't want to have to carry two remotes one for the back door and one for the front door. Thanks.
Not sure which lock you have but most Radio Frequency (RF) locks are programmed to recognize the remote (some as many as 15). So you would program each lock to remember your remote and this will allow you to use the same remote for both locks. Be careful about range though.. if you are using one lock on the front door and the other on the back do you will controlling both locks when you press the button. But if you are planning on each lock being at a different house then you will be fine.
May 06, 2010 | Morning Industries 3-in-1 Keyless Entry...
I am not able to use the hand held lock/unlock now. The driver door lock tries to work, but it won't. If I push the lock down manually, it will lock all locks. What could be wrong?
Note:
Entering the programming mode cancels all learned keyless remotes, so none of the
previously programmed remotes will work. You must reprogram all of the keyless
remotes once you are in the programming mode. You must complete each step within 5 seconds of the previous step to keep the
system from exiting the programming mode.
1. Turn ignition switch to ON (II)
2. Press the LOCK or UNOCK button on one of the remotes. (An unprogrammed
remote can be used for this step.)
3. Turn ignition switch to LOCK (0)
4. Repeat steps 1, 2 and 3 two more times using the same keyless remote used
in step 2
5. Turn the ignition switch to ON (II)
6. Press the LOCK or UNLOCK button the same remote. Make sure the power door
locks cycle to confirm you are in programming mode.
7. Press the LOCK or UNLOCK button on each remote you want to program. Make
sure door locks cycle after you push each remote button to confirm system has
accepted the remote.
8. Turn the igniton switch to LOCK (0) to exit programming mode.
9. Test remote(s)
Mar 07, 2010 | 2002 Honda CR-V
As to me to stitch the second key from ignition (with immobilizer) in memory of my car (Honda CRV-2,4 EX 2002, made in UK) if nearby is not present diller from Honda.
Programming
When
Remote control added or replaced. System malfunction.
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 8 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control
NOTE THIS IS FOR YEAR 99-02
Mar 02, 2010 | 2002 Honda CR-V
How to recode remote to vahicle
Programming
When
How
Obtain all remote controls. A maximum of 3 remote controls can be programmed. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press lock or unlock button. Within 10 seconds: Press lock or unlock button of first remote control. System should now lock or unlock vehicle. Press lock or unlock button of second remote control. System should now lock or unlock vehicle. Press lock or unlock button of third remote control. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed remote controls.
NOTE: If less than 3 remote controls are to be programmed, remove ignition key after programming last remote control.
Jan 18, 2010 | 2003 Honda Civic
How to program a 2009 Honnda Accord Key Remote
Want to programs the remote key of your Honda cars, then you must reprogram all of the key-less remotes of your Honda Accord once you are in the programming mode. You must complete each step quickly so to prevent the system from exiting the programming mode.
Note: Maximum Three remote transmitters can be programmed.
Make sure all the doors are UNLOCKED before starting this programming procedure.
2. Press the LOCK or UNLOCK button on one of the remotes. (An unprogrammed remote can be used for this step.)
3. Turn ignition switch to ACCESSORY (I) or LOCK (O)
4. Turn ignition switch to ON (II)
5. Press the LOCK or UNLOCK button on one of the remotes.
6. Turn ignition switch to ACCESSORY (I) or LOCK (O)
7. Turn ignition switch to ON (II)
8. Press the LOCK or UNLOCK button on one of the remotes.
9. Turn ignition switch to ACCESSORY (I) or LOCK (O)
10. Turn ignition switch to ON (II)
11. Press the LOCK or UNLOCK button the same remote. Make sure the power door locks cycle to confirm you are in programming mode.
12.Press the LOCK or UNLOCK button on each remote you want to program. Make sure door locks cycle after you push each remote button to confirm system has accepted the remote.
13.Turn the ignition switch to LOCK (O) to exit programming mode.
14. Test remote(s)
For more clarification, i have also shared the video to do this process, Have a look
Apr 09, 2009 | 2009 Honda Accord
Keyless remote
Note:
none of the previously programmed remotes will work. You must reprogram
all of the keyless remotes once you are in the programming mode. You must complete each step within 4 seconds of the previous step to keep
the system from exiting the programming mode. You must program remotes
within 10 seconds of each other
2. Within 4 seconds press the LOCK or UNOCK button on one of the remotes.
3. Within 4 seconds turn ignition switch to LOCK (0) position
4. Within 4 seconds turn the ignition switch to ON (II)
5. Repeat steps 2, 3 and 4 two more times using the same keyless remote
used in step 2
6. Within 4 seconds press the LOCK or UNLOCK button on the same remote.
mode.
7. Within 10 seconds press the LOCK or UNLOCK button on same remote.
8. Within 10 seconds press the LOCK or UNLOCK button on all other
remotes you want to program. Make sure door locks cycle after you push
9. Turn the igniton switch to LOCK (0) to exit programming mode.
10. Test remote(s)
Dec 24, 2008 | 1998 Acura TL
Denon DRA-397 Logo
1,281 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
