Question about Alpine CDA-9884 Car CD/ MP3 Player
Power on, no sound, very few controls work
The power is on. I can us the "Source button" fine to change between Tuner, BT, etc. If I select "tuner" mode, nothing else seems to work; preset bottons don't work, no sound comes out (no volume control), the arrow buttons do not work, etc.
In the BT audio mode, it seems to link with my phone, but no sound.....volume control is not working.
I have opened up the unit and pressed the "reset", but this did not help.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the wiring for your Player, and make sure that no connections are loose or cut. Also check the relay and fuse for your stereo. This issue can be due to loose wiring when enough power/polarity is not fed to the Player. However, if the issue is not due to wiring or fuse then it is an issue with the internally blown resistors or bad contact switches on the player board.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 20, 2009
How do I connect a dvd player with surround sound?
This depends on how you have it hooked up. You're going to need a Tuner. A simple method is to connect only the Yellow RCA cable (or composite cables) to your T.V. Then connect Red and White RCA cables to the Tuner/Surround sound system you're using on which ever input you're comfortable with. I.E. CD/AUX/TAPE..etc. Change your tuner to that input, and you should get your surround sound through the speakers. Make sure you change the input on your T.V. to what ever video source you got the wires in. If your tuner allows you to hook up a video source to it, you can just hook it up to the tuner and run the DVD player off the tuner only. The first option helps avoid confusion if your tuner isn't set up for any other devices to play video through it.
Jun 24, 2011 | NEC 42VP4 42 in. EDTV-Ready Plasma...
Sony TV problem.
Chances are the CRT has expired. In that case I would recommend replacing the entire unit.
Mar 06, 2008 | Video Game Consoles & Games
I have a cms1 clarion unit. The tuner portion quit working but the rest still works fine. The tuner is stuck on one frequency and will not change or tune to other freqs, also there is no sound coming out....
The tuner portion is in the head unit, and sounds like non-repairable problem. If you decide to sell please let me know, I destroyed my amp box of my CMS1 cutting it up to fit inside my motorcycle.
Mar 30, 2010 | Clarion CMS1
Has sharp 42 inch aqous got inbuilt digital tuner
Hi www_andremou
You are right. It has got a digital tuner. After you power on, press the Menu button on the Remote Control, select Setup. Select the Auto Installation. The Inbuilt digital Tuner will search for all the available channels r and tune automatically.
If you wish change the Volume and Screen etc
The Instruction manual gives full details.
Good Luck
luciana44
Dec 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
This is my problem with DENON AVR 700RD: I lost remote control and I don't know how to turn on it.... I've tryed selecting "TUNER" or "CD" etc. but nothing has happened... What can I do? Can you help me,...
Hold the following TUNER button and VIDEO SELECT button and turn the main POWER button on. This will initialize the microprocessor and start the receiver. After this you can use the POWER button normally to power on/off the receiver.
Jun 06, 2009 | Audio Players & Recorders
Can't select satellite option when pressing source button.
The Sirius Tuner is separate from the AM/FM/CD, check the plugs between the two. If all is snug, pull the SIRIUS tuner and go to a JVC dealer that would have any deck w/sirius as an option and plug it in. If it sees it, it's more than likely a problem with your deck. My guess is it's a bad SIRIUS tuner. There have been LOTS!!! Good news is there easy to replace if bad, and there cheap! $45.00 from Crutchfield rebuilt.
May 22, 2009 | JVC KD-HDR30 CD Player
Connection compatibility
Connect the supplied short RCA "Y" adapter cable to the mini jack of the transmitter base unit. Connect the "Y" adapter plugs to the TAPE 2 "REC" L and R jacks. These jacks will supply "line out" levels of any source selected at the Kenwood to the EWOS1 internal amplifier. The line out levels are "fixed" so changing the volume levels of the Kenwood will NOT change the volume out of the EWOS1 speakers. The EWOS1 volume will be controlled by the volume up / down buttons on the front of each speaker, or by the incuded remote when directed at the speaker(s).
The signals from the TAPE 2 jacks are ALWAYS on regardless of the source selected, so the Kenwood volume can be turned to minium and still provide an unchanged sound level from the EWOS1 speakers. Likewise, if listening to FM, Phono, CD, etc. in the room that the Kenwood's speakers are located, the OWS1 speakers will by playing the same FM, Phono, CD, etc program - unless they have been powered off. The point is, that unlike having to choose FM, CD, etc to listen to those soreces, you should never select TAPE 2 as a source. If TAPE 2 is selected, the KENWOOD would attempt to amplify TAPE 2's "PLAY" jacks, which I assume are not being used.
Mar 20, 2009 | Audio Players & Recorders
Standby button fails to go green
if there is a remote control does it work from it?
have you tried removing power from the wall for a few minutes then retry, sometimes the computer inside gets scrambled brains and a hard power reset might wake it up.
Feb 09, 2009 | Philco 841.169 Turntable
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
No channels above 47
That works great except I can get the tuner to program any channels above channel47. Is this a limitation of this older model TV yes there is limitation in old tv. is there some setting I can change in order to get more channels using the tv tuner? in INDIA what we do is put a remote control ckt which gives us about 250 channels. of course we replace tuner also called hyper tuner along with remote ckt or replace whole kit which are cheaply available.& serves the purpose. hope this will help
Oct 03, 2007 | Televison & Video
Alpine CDA-9884 Car CD/ MP3 Player Logo
142 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
