Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I went to start my 1997 HD FLSTC. It turned over
I went to start my 1997 HD FLSTC. It turned over once and all the power was lost. Dead, nothing happening. It has a new battery. I need to know how to check the fuses or the main fuse.
  • 116 Answers
Ignition switch common for your bike less expensive aftermarket but do make sure to solder in new connector at the same time
Posted on Dec 31, 2009
I have a Compaq CQ61-411 Notebook the battery went out the computer was working great but a message came up saying replace battery and it cut off and would not charge back up so it took me a few months to...
HP.com
see your manuals and what the blink codes mean.
each PC has PDF manual that covers that.
blink codes are BIOS warnings.
to tell you what catastrophic failure happend
like low power
bad memory
processor dead
GPU dead.
and more, some have 12 errors possible (newer)
if the BIOS screens are dead, its lost power.
or one of the above.
Mar 20, 2017 | HP Compaq Presario CQ61410US Notebook
The car won't start after being turned off for a while. We replaced the battery already and now the new battery went dead. Something is draining the battery down to nothing, but we can't figure out what.
most wiring problems occur at rear of vehicle check for a wire rubbed thru bare on suspension drivers side frame also check wiring around starter and also taillight wiring at back end....if itwent dead siitting there then power drain is on right track it is fine once running alt chargeing proper?
Mar 19, 2011 | 1997 Buick Century
I recently relaced my starrter for my car and when I went to start it up nothing happened. I checke the battry and the starter nothings wrong with them
Does the car make any noise when you turn it over? If it clicks when you turn the key the battery is dead. Quickest way to check a battery is to switch your high beam on. Get out and check the lights. If they are dim then the battery either needs charging or replacing.
How old is the starter? New or used?
Jan 18, 2011 | 1997 Hyundai Accent
HD 1200 XL Nightster, hadn't been started in a couple of months so battery went dead. Put in a brand new HD battery (full charge). Turned ignition switch, nothing..at all. Checked all my connections,...
I don't know a lot about the electronics on the newer bikes. I work on older stuff but it sounds like the security system has nailed you. That would be my best guess.
Good luck
steve
Aug 11, 2010 | Harley Davidson XL 1200 C Sportster Custom...
Put in new battery still no power. was riding and everything went dead. the bike is a 98 cbr 1100
Hi and welcome to the site,
Initially, have you checked the 30A main fuse? It would be inside the starter relay. To locate the starter relay, follow the cable from the battery's + terminal.
Good luck and thank you for asking.
Jun 03, 2010 | 1998 Honda CBR 1100 XX Super blackbird
When turning key all the way over it simply does nothing what could it be
You'll likely need a new ignition switch. (The electrical side) You can confirm this by pulling the lower steering cover when issue is occurring, and using a test light on the black and yellow wire when turning key to "Start" position. If test light doesn't illuminate, replace switch. (Easy)
Thank You for contacting Fixya.com
Aug 03, 2009 | 1997 BMW 328
Electical short, bike wont start
When you shorted with tool you may have caused a wire to burn through insulation to ground? You could try to disconnect wiring until sparking stops.
Jul 27, 2009 | 2003 Harley Davidson FLSTC Heritage...
2001 grand cherokee ltd completely lost power
Check the connections at the battery. Be sure they're clean and tight.
May 09, 2009 | 2001 Jeep Grand Cherokee
Lands Phones Logo
161 people viewed this question
Top Harley Davidson Lands Phones Experts
Gar
Gar
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
