Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
When my washer gets tio spin cycle it makes a grindding sound and it seems to wobble to much, even when the washer has no colthes in it.
  • 38 Answers
Something to check would be the two aluminum bolts in the clamp block that holds the basket assembly to the transmission crank.
If one breaks, one side of the basket can drop enough to rub on the plastic water tub.
Its an easy test, they can be examined by simply removing the agitator.
If indeed one is broken, I suggest replacing both of them with brass bolts. (two brass bolts from the hardware will be cheaper for you than one OEM aluminum bolt)
Quentin
Posted on Sep 26, 2009
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Loud in spin cycle/throws oil
If the pulley wobbles, it sounds like a bad bearing, and that could account for the oil/grease. One more thing you might check, mine acted bad in the spin cycle, but mine was the leveling spring at the bottom of the drum. The way to tell from the top is if the drum tends to lean forward instead of being centered when sitting. Good luck.
Jan 08, 2018 | Maytag MAH55FLB Front Load Washer
Washer not spinning
Does it make any grinding noise or other sounds when it is spinning?
Nov 03, 2012 | Zanussi Washing Machines
Our washer is making a grinding noise when the washer drains and when the tub spins any ideas what it might be. Washer seems to work fine just making that noise during a drain and spin cycle.
This sounds like you may have something caught in the drain pump. One of the most common items to get stuck in there is a woman's bra wire. Check it out.
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When spinning it seems the washer is getting louder and louder during the spin cycle. It is a very steady noise no grinding to it. Maybe a bearing?
make sure heavy items are evenly distributed in the barrel. if to loud , stop the machin by openning the lid and make sure the weight is evenly distributed. never just throw laundry in , place it so wieght is evenly placed around.
Jun 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Weird rubbing or mild grinding noise when in spin cycle.
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Feb 07, 2009 | Kenmore HE2 Plus Front Load Washer
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
97 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
