Question about Whirlpool LER4634J Electric Dryer
My dryer won't start, but I think the cycle button won't engage.
My electric dryer is about 9 years old. It won't start when start button is pushed. But I think the problem is in the cycle selection button. For a few weeks I have had to toggle it in and out before I push the start button to get it to start tumbling. I definitely think it's the cycle selection button.
  • dgbaron8 Sep 20, 2009
    My husband checked. It is not the fuse. The wiring is not burnt. We do hear a ticking sound when the selection button is turned but it still won't start.
    President:
  • 710 Answers
THERE IS A SWITCH THAT IS LOCATED ON THE OPPOSITE SIDE OF THE DOOR. SOME OF THESE SWITCHES ARE OF THE PLUNGER TYPE. TRY PUSHING THE PLUNGER IN WHILE STARTING THE DRYER, MAKING SURE THAT NOTHING IS IN THE PATH OF THE ROTATING DRUM. IF THE DRYER STARTS, THEN EITHER ADJUST OR REPLACE THE PLUNGER SWITCH. THANKS FOR USING FIX-YA. PLEASE KEEP ME POSTED. GOOD LUCK
Posted on Sep 22, 2009
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The issue might have happened due to a blown fuse or burnt wiring/components on the control board. You'll need to check and replace the fuse and replace it.
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Sep 20, 2009
  • Rylee Smith
    Rylee Smith Sep 20, 2009
    Hi
    Thanks for using FixYa. I think i was helping you, don't know why you rated my solution as "not related". Please check part #5 thermal Fuse--
    A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it.
    Your dryer may not be receiving adequate voltage to start. Make sure your dryer is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your dryer. Also, refrain from using an extension cord to plug your dryer in.
    A defective dryer thermostat could be what is preventing your dryer from starting. Open up your dryer's cabinet. Test each of your dryer's thermostats. Replace any that have become defective.
    A burned out motor could be what is keeping your dryer from starting. Test your dryer's motor and if it is defective, replace it. You will have to open your dryer in order to gain access to its motor.
    Check if the ventilation ducting to ensure that it is not kinked or clogged. Poor air flow is the number one cause of dryer failures. Not to mention it can cause fires due to lint backing up inside the dryer. This could be the "electrical" smell you've experienced. If trapped lint is ending up on the heating element it will smolder and burn.
    Please do change the rating for the solution and revert for further assistance.
    Thanks
    Rylee
Fisher Paykel Dryer Model DE08-US1. Dryer won't start. When pushing the start button, there is a "humm" from the electric motor - like it's trying to start. Very sudden problem. ...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 18, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
May 23, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer model # ALE866SAW approx 9 years old ran great until tonight. Went to touch up load of whites (socks underwear etc) and get a sound from the back that sounds like an electric motor that just went on...
Yes it sounds like the motor is bad and that is very fixable, but what about the belts the guides and the wiring??? If this has been used hard ( more then 6-8 loads a week for 9 yrs then I would go new...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 09, 2010 | Dryers
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Dec 30, 2007 | Dryers
Whirlpool LER4634J Electric Dryer Logo
920 people viewed this question
Top Whirlpool Dryers Experts
Sal De
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
