Question about Evga Computers & Internet
Dont have a manual an the accessory kit for a
Don't have a manual an the accessory kit for a brand new evga 681I sli motherboard, can I order them? where? thanks
    President:
  • 1,015 Answers
Hi can i install evga gforce 9500 gt video card
Yes, it will work just fine. Just make sure you uninstall the drivers of the embedded one before installing the new one and you disable it from the BIOS immediately after.
Apr 18, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
EVGA x58 SLI LE + VIA VT6421A RAID card Install without os?
There are many tools you can use to install RAID stuff. For example Hirens Boot CD http://www.hirensbootcd.net/details/10.2.html - the download may be broken but google it and you should find it quickly.
(http://www.hiren.info/downloads/freeware-tools/)
Also if you need to boot from a USB then try UNetbooin or  some of the tools mentioned on the site.
This should help to install RAID there are many tools on here. What kind of fussy os has to use SATA dvd drives anyway.
Nick
Mar 05, 2010 | Evga X58 SLI LE (25139) Motherboard
Systemboard drivers
You have an nForce 590 SLI AM2. The only drivers available are at EVGA's website. Since you didn't say what OS you're using, here is the link. If the drivers are not at that link you must email EVGA and ask for them.
Apr 24, 2009 | Evga (122-M2-NF59-TR) Motherboard
Msi sli with evga 7900 gtx video card,doesnt post or turn monitor
The video card is not compatable. Also check your ram first to make sure it is plugged in all the way, and the rest of your hardware.
Feb 28, 2009 | MSI K8N SLI-F Motherboard
Is my CPU fried?
if it was your cpyu, you wouldnt get error codes or beeps. perhaps the problem is your power supply or bad ram.
Dec 29, 2008 | Evga (122-CK-NF68-T1) Motherboard
Evga 680i motherboard no signal on monitor
Nice Mobo by the way. Are you using Vista or XP? Does the board POST?Do you use the SLI feature?Does the bios hand off to Windows? If you can answer these questions it would help. I have more questions but I would like to start with these
Nov 28, 2008 | Evga nForce 680i SLI (122CKNF68)...
ASUS Striker II Formula Motherboard and SLI Problem
The Dominators are high performance memory. They are spec'd for 2.1 volts, so you must set the DRAM voltage in your BIOS to 2.1 volts, not the standard 1.8 JEDEC specification. Also, make sure you set your latency timings to the following:
5=CAS Latency=TCL
5=RAS# to CAS# Delay=tRCD
5=RAS# Precharge=tRP
15=RAS# to Activate to Precharge=tRAS
Command Rate 2T
These settings should automatically populate in one of your EPP profiles.
-E
Oct 29, 2008 | ASUS Motherboard Striker II Formula
Open Questions:
Reset button on EVGA motherboard solid yellow I have an EVGA X58 SLI Motherboard, model 132-BL-E758. My 1200w power supply went out and I had to replace it. I did so with a Corsair 860 hoping it would do the job. I'm running a Radian 7970 video card. I understand it needs a 550w power supply so this should be enough. It may not be. The computer kept shutting down. The Motherboard lights were still on so I presumed the power supply was still working. I checked all my wiring to the Motherboard and may have created a problem. Now, although the fans come on and the Motherboard lights up (green, yellow, and blue lights in the middle of the board) the computer won't start up. The monitor says No Input. I hear nothing to suggest the drives are turning or loading Windows (7). Additionally, and where I hope someone can help is that now my red LED light next to the start switch on the computer case won't come on when I press the start button. Looking inside I see that although all three lights are on (green, blue, yellow) the green power button (next to the yellow reset button and red CMOS button) is not on. Additionally, the yellow reset button is lit up and pressing it doesn't change anything. The question is, is the yellow reset button and green power button on your Motherboard supposed to be lit up, or off? Secondly, with the reset button lit up and the power button off, does that tell you anything? If so, please share that with me. I'm at a loss as to whether I have a possible Motherboard problem, or whether the problem lies in the possibly undersized power supply that I installed, or if I've wired this incorrectly. If all fans come on and the board lights up, does that suggest that the board is fine or could there be a part of the board that isn't working and causing this problem? Because I wired this myself when I installed the new power supply is it possible that I've not installed a wire? Do these symptoms tell you anything that can help me or lead me in the right direction?
Jan 15, 2018 | Evga Computers & Internet
Computers & Internet Logo
161 people viewed this question
Top Evga Computers & Internet Experts
David
David
Larry Rider
Larry Rider
Josh Levin
Josh Levin
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
