Question about Fantom Drives 120 GB Hard Drive
Drive not being detected
I have 2 of these 120GB drives I use to back up a NAS, swapping the drives each week for redundancy. This happened once before and I used the backup power supply which fixed the issue for a while. Now again, neither drive is being detected. Pwr sply seems to test good, But neither drive will be detected anymore. I believe this is power related.
    President:
  • 2,923 Answers
I don't think it's a power related issue. Hard drives are very sensitive, swapping the two HD would cause a problem. Do you hear a clicking sound while the HD is turned ON? If you do, I'm regretfully informing you that the HD is starting to quit working. Bad sectors are starting to increase.
I would advise you to try connecting the problem HD to another computer. If the HD is detected by another computer, back up all the files and then reformat the problem HD. After reformatting the HD, restore the files that you back up from another storage and it should be working again.
Have a great day!
Posted on Sep 20, 2009
I have a buffalo nas and took out one of the drives from it. It's set up as raid0 on that nas. I added that hard drive to my dell Inspiron 690 using the sata connection. I spotted that it was detected on...
Open 'Administration Tools', select 'Computer Management', click on 'Disk Management' and see if it populates there. If, in fact, it does show up here, then chances are it simply does not have a drive letter assigned. If this is the case, you can simply right-click on the drive, select "Change Drive Letter...', and assign a drive letter to it. Please see the step-by-step below:
Sep 24, 2013 | Dell Precision Workstation 690 - 750W...
Tip
How to choose a backup device
Hello all,
I work in data recovery and I'm always being asked what kind of backup device my customers should use. The fact is, there are a lot of choices and a lot of different situations with different answers.
Whatever device you choose for backup, remember the most important part of backing up is to always have more than one copy. Your backup device does you little good if it holds the only copy of your files.
USB Flash drives:
Pro's Cons
Most Inexpensive Easy to damage
Easiest to Transport Easy to Lose
High Compatibility Difficult to recover
Fast copy speeds
External Hard Drives:
Pro's Cons
Inexpensive Some are bulky
Higher Capacity Greater damage if dropped
Easy to transport Can be expensive to recover
High Compatibility Some require external power
Faster Copy Speeds
Easier to recover
More rugged
Secondary Hard drive(internal)
Pro's Cons
Inexpensive Not optional on most laptops
Higher Capacity Not optional on all Desktops
Fully compatible Can fail simultaneously
Fastest Copy Speeds Does not protect data if PC Stolen
Easy to Recover Requires some knowledge to install
More Rugged
Less risk of damage
NAS Box or Small Server
Pro's Cons
Higher Capacity Higher Cost
Redundancy is Optional Requires more knowledge to setup
Accessible to all PC's
on your network at once
Fast Copy Speeds
Low risk of damage
Compatible with most PC
RAID5 NAS or Server
Pro's Cons
Highest Capacity Highest Cost
Highest Redundancy Requires most knowledge to Setup
Fastest Copy Times Requires specialized equipment or software
Accessible to all PC's Most expensive to recover if failed
Ability to survive single
drive failures without
data loss.
Now, armed with that short list of options, let's help you decide which option best suits you. If you move around a lot, you go to school, work out of the office or travel for work a USB flash drive is often the simplest form of backup and allows you to move data between home, office or school without lugging a large drive around. we recommend these as a part of most peoples backup solution. Next you will want a more stable form of backup(harder to damage).
For your tougher backup device you will have to decided what kind of budget you have, how much data will need to be backed up and how often. If you have a great deal of data from several computers in your home or office you will likely want to use a NAS box or setup extra drive(s) in one of your existing desktops to use as a server. If you only have one or two computers or the budget just won't cover a RAID or NAS solutions you can simply purchase an external USB or eSATA hard drive, usually less than $100. This can be moved between computers and used for backing up.
Now remember to Sync your data. This means anything you update or create while away that is saved on your USB flash needs to be copied into your computer and your computer needs to be backed up onto the external drive or server.
For more information on backing up, verifying backups and different types of backup devices, visit my blog at http://www.aitsavemyfiles.com/armor-itrecoveryblog.php or search through the other tips available here on FixYa.
on Mar 19, 2010 | Computers & Internet
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
My Samsung 1.5 TB external hard drive spins up and makes about 5 clicking sounds. My laptop cannot detect it. What can I do to recover the data.
A clicking sound for samsung drive is most like due to faulty heads and the only way to recover data off it is to perform a head swap. You need to buy a compatible donor online like ebay. If you don't know how to do this, i suggest you send it to data recovery company, as this is a very dangerous procedure. It can cause severe damage on your hard drive if you perform it without any knowledge and the right tools to do it.
hope it helps.
May 05, 2011 | Samsung HD154UI 1.5TB 1500GB SATA DRIVE...
Hi, I want a program to create recovery disks for my laptop, ie if my hard drive fails I can then use the disks to reinstall my operating system on a new hard drive without using windows install disks with...
Take a look at Acronis True Image http://www.acronis.com/homecomputing/products/trueimage/index.html
I use this and a device called Blac X at: http://www.thermaltakeusa.com/Product.aspx?S=1268&ID=1642
along with an extra drive to make an exact duplicate of my lap top drive. I then am able to swap the drives out if any thing happens.
You can also make Cds or DVDs of the image and use that to restore your drive.
I find the extra drive method, much more advantageous as I am only down for a few minutes. I make the extra drive about once every two weeks and swap drives each time so as to ensure that they both were working.
Feb 02, 2011 | Computers & Internet
I have a usr8700 NAS running raid 5. I had a drive fail and now I cannot access any of the data. I am researching the options of recovering the data. I found a few products and service options but don't...
Hello, I don't know your particular NAS, but a raid 5 is able to survive a single drive failure and continue to supply data ok because it recreates it from the remaining drives plus the parity drive. But, if you then get a subsequent drive failing before you've replaced the original failed drive, (and restored the data to it, which is/should be automatic) then it's really bad news. So, if you definitely have only had a single failed drive then you should just get an alert to warn you to take remedial action- ie, replace the drive. If the NAS has stopped supplying data then you may have got a multiple-drive failure situation. Just a general note of caution when working on a raid array: Some raid systems are clever and you can switch your drives around, some aren't and you can 'break' these raid sets just by swapping the positions of 2 drives, which is too easy to do if they're not labelled and you're trying to faultfind ...so unless you're absolutely certain, just label your drives (and take a photo) before starting to swap drives about. Anyway,good luck with your troubleshooting.
Regards
nicam49
Dec 24, 2010 | U.S. Robotics SERIAL ATA 4DRIVE NAS...
Fastora NAS-104WR
It all depends on how mission critical this NVR is, (and how much money you have to spend)
A good rule of thumb is the more redundancy the better, so in theory, if you have the money, you should buy the second NVR, however if you cant afford an entire second unit, you should look at doing hard drive backups of that unit.
If you have any more question, please let me know!
Thanks,
Mike
May 17, 2010 | Fastora NAS-104 (nas-104d) 0.25 GB Hard...
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Cannot detect the lacie 1tb exreme big disk
Hi there!
Same issue here
Running win XP on my laptop and I have my LaCie NAS on my network and was working fine 'til today.
Issue: unable to access my LaCie NAS
troubleshooting done:1- rebooting NAS 2-power cycling the whole network 3- also tried accessing NAS from a Mac Book (used to be able) 4- nable to ping it by name or by IP
I had one my NAS's shares mapped to Y:, Now I can see the share from my network places but when I go to map network drive the Y: is no more assigned to that share.
My next move would be to re-install the NAS but I want to know and make sure that this will not delete what I have on that NAS.
Thanks to anyone that would jump in and give a hand to a desperate novice in Networking
Sep 30, 2009 | LaCie Big Disk Extreme (300797U) 1000 GB...
NAS Drive by ADS Tech not recognized on network.
You can log into your router and find out what IP address has been assigned to your NAS unit.
Then start up Internet Explorer Or Firefox and go to the address http://xxx.xxx.xxx.xxx (replace with the IP address of the NAS unit).
That should get you in. Then you will have to set the workgroup and share parameters. Once you have it setup you can always map the NAS unit and use it as a external hard drive.
Dec 18, 2008 | Computers & Internet
Fantom Drives 120 GB Hard Drive Logo
214 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Computer Links
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
