Question about Blue Schiffmayer Plastics Kart Ahoy
The handle has broken at the bottom of cart. what
Is the handle replacement the whole handle or is it just part
I have a 360 tour tree golf push cart and I the cover is broken on the handle where can I get a replacement
It would appear that you can't get any parts or service on them. Probably made in China and badged 'Tour Trek'.
tour trek golf push cart repair Google Search
Aug 01, 2017 | Golf
Top coupler on gas pump handle ONLY (Majestic 360 SS) is broken. Do we have to replace whole hose and handle assembly?
They now make a replacement tab so you don't have to replace the entire handle grip. The bad part is, most of the time it's the handle grip that has the broken place in the plastic, not the latch tab. That too can be bought seperately though, so you don't have to buy the hose. Call your local vac shop for assistance.
Oct 21, 2014 | Filter Queen Majestic Canister Vacuum
Bretford iPad Cart Static Electricity problem
This was straight from a Bretford tech:
There are no capacitors or anything that can hold a charge on the cart itself. The only thing that we've been able to come up with thus far is that dry air in the schools may help generating static electricity. Common precautions would be 1. make sure the ground plug is still on the cord. (This can get broken off if the cart is moved with the cord still plugged into the wall.) Plugging the ground cord in won't help however if the person has to grab the door handle to open the door to get to the wall outlet. 2. If the air is dry (ie: people get shocks even without the cart or the problem goes away in the spring when the humidity goes up), gently push the metal of the cart handle against the door frame prior to reaching for the door handle. This will discharge any static electricity that was built up as the person walked with the cart safely to the door jamb prior to the person reaching for the door handle.
Nov 20, 2012 | Apple Computer Apple Bretford PowerSync...
Broken door handle on fisher & paykel e388
look for the model number at the front, bottom of the fridge where the door meets the fridge body (eg 22021-D). Go to shop.onlineappliancespares.com.au and either buy the whole handle ($150) or just the broken lugs ($15)
Nov 17, 2012 | Refrigerators
Where can i buy chicco polly high chair replacement straps?
I did alot of searching on the internet for straps and found highchairbelts.com that didn't charge an arm and a leg for shipping or handling . One strap was $9 shipped so I bought three for $17 shipped FREE!! I sewed the ends of one strap together to use with Marissa's shopping cart cover at the grocery store. The ones on the carts are usually broken or missing and end or just plain filthy!
Mar 01, 2010 | Chicco Polly Highchair
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Have Maytag Model #MER5765Q - Door handle came off (slight weight on it caused it snap off). No broken/sheared bolts or broken plastic. Can't figure out how to reinstall. Help!
u have to take whole door apart to get to it . remove the door then take screws out from bottom and sides then u can removbe the glass to see the other screws helping to hold handle on
Mar 17, 2009 | Maytag MER5765Q CleanDesign Electric...
One of two handles broken
I had this happen once. I contacted Rival about mine and they exchanged the whole unit. They even sent a box to ship it in prepaid! The whole process took about 3 weeks.
Jan 03, 2009 | Rival 38601 Smart Pot 6-Quart
Problem with Sharp AR 337
are you refilling the toner cart? if yes..
An easier way is to take out the whole developer unit. Pull down green handle as if you were replacing the toner, there is to the lower right of the developer unit a white handle that if you move to the right will allow you to remove the DV unit. Then there are 5 or 6 screws around the top edge that will allow you to remove the top and manually refill it there instead of trying to refill the cart and making a bigger mess.
Hope that helps...
Jun 20, 2008 | Sharp AR-M237 Copier
New refill but runs out of ink after about 8 pages
Did you stich into the ink inlet within the cart holder with a syringe for pressing some air into the tubes? Never do that! Because you have dissolve the bottom of the cart holder or drilled a hole into the bottom.
The cart holder leaks and the poured out ink has already stained the whole machine!
The bottom of the cart holder is a foil which has been sticked onto the hard plastic (clever , eh?). This also happens due to the use of  a wrong refill ink or wrong generic carts the wrong mixture dissolves the foil and ink runs out into the machine....
You need a new cart holder to fix that.
Jan 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Blue Schiffmayer Plastics Kart Ahoy Logo
32 people viewed this question
Top Blue Toys Experts
Marvin
Marvin
Tom Chichester
Shawn Hudson
Shawn Hudson
Are you a Blue Toy Expert? Answer questions, earn points and help others
