Question about Philips Magnavox 27MS343S 27" TV
  • vhaymon Nov 20, 2008
    great picture no sound
  • Philips Master
  • 5,138 Answers
First check to see if sound has been turned off go to audio in menu if off which to on if this does not work then chk your speaker ,if speaker is good then you might have a bad audio output chip.
Posted on Dec 23, 2007
What is wrong with my Samsung HLS42WX/XAA everytime I turn it on after ten minutes the volume start making a loud crackling sound then there is no volume sound at all. What do I need to do to get this
It clearly may be a sound problem in the set but a few things you might check, First of course is do you have this issue on all inputs including the rear ones, does a DVD player connected to a rear input do this or not?
If you have a box connected to this set unplug both the box and set from power for a while, cannot hurt but may help.
If using a box and set does not do this with a DVD it may be possible to get around the problem.
A box or even the tuner in the set may be the cause==your tuner not only processes regular signal but also develops the sound signal, it may be bad.
Dec 23, 2012 | Televison & Video
No sound
Check the usual things:
In menu speakers not switched off.
Set not set to external speakers if equipped.
Does the set have sound when a DVD connected to a rear input is used?
Oct 29, 2012 | Insignia NS-LCD32 LCD TV
57hdx82 no picture poping sound when I turn on set
sounds like either a power supply or High voltage circuit problem and not likely a do it yourself repair
Mar 11, 2012 | Toshiba 57HDX82 57" Rear Projection HDTV
When i turn on no sound comand
Once you have started yout tomtom, go into Change Preferences and observe the icon for the sound setting. This is on page 1 of 5. If the sound is set to be off, you will see a speaker image, with the legend Turn on sound underneath. Tap the icon, and this will turn the sound back on again. Hope this helps.
Jan 27, 2011 | Tomtom ONE GPS Receiver
Plug the speakers into your iPod. Any sound?
You may need to maximize the volume-control on the iPod *AND* on your speakers, but you should hear some sound, if the speakers are working.
Try a different set of speakers on your computer.
Make sure that you have not "muted" nor "minimized" the sound on your computer.
Make sure that the speakers are plugged-in to the "green" socket on your computer.
Sep 14, 2009 | Audio Players & Recorders
How do I turn the monitor volume on for a norcent
Please try to go to Control Panel > select Sound, Speech and Audio Devices > select Sound abd Audio Devices > then at Speaker Set-up select Monitor Stereo speakers. Best regards
May 12, 2009 | Norcent Technologies Computers & Internet
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Nov 21, 2007 | Philips 28PW6506 28" TV
Hissing Sound
A hissing sound that comes from the back of the set (not from the speaker) usually indicates a high voltage leak, most likely around the "suction cup" at the top of the picture tube or around the flyback transformer. Remove the back of the set and turn it on, and when you hear the hissing sound, shut off all the lights in the room and you should be able to see a purple-ish or white-ish glow from the spot that is hissing. Shut the set off, discharge the high voltage and clean and seal the problem area. Of course this should be done by someone experienced with stopping high voltage leaks.
Jun 22, 2007 | Durabrand DU1901 TV
TV wont turn on?
this product has a bunch of exotic semiconductors that only a tech could replace in my parleyance its called NECO
Dec 08, 2006 | RCA 27R410T 27" TV
Philips Magnavox 27MS343S 27" TV Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
